Home Depot Dustopper - 2 1/2 inch separator - Router Forums
 25Likes
post #1 of 16 (permalink) Old 03-18-2018, 08:12 PM Thread Starter
kp91's Avatar
First Name: Doug
Default Home Depot Dustopper - 2 1/2 inch separator
Tool: Dustopper High Efficiency Dust Separator, 12 in. dia, with 2.5 in hose, 36 in. long
Reviewer: Doug KP91
Tool Rating: 9
Picture: see below (and I don't know why, but every picture taken by my iPad shows up upside down!!)
Review:
I converted the dust collection on my CNC from the smaller dust hood to a 2 -1/2 inch connection dust hood to increase efficiency. I cut a lot of Corian and similar products, and the dust would stick in the smaller hood because of the static and foul it up. Going to the larger hose has been a vast improvement in both effectiveness and noise reduction.
My big shop vac has a clean-stream hepa filter on it, and it clogs quickly with the fine dust, and has to be cleaned a lot. To reduce the intervals I have to clean it, I thought I would try this little cyclone that sits on top of a bucket. It was not sold in my store, but I saw it when I was up helping out my parents and had to make a HD run. It was about $35, I already had the bucket.
The unit is pretty simple, you get the separator head and a length of hose to go between the cyclone and the vacuum. You use your hose on the inlet side. Nothing complicated.
I emptied the shop vac, hooked up the separator to the CNC, and took a 2 thousandths cut on the spoil board. After surfacing 8 square feet of MDF, I took a look inside the shop vac and the separator. I think the pictures show the results pretty dramatically.
So far the only complaint I have is that the lid fits almost too tight on the bucket. The effort it takes to get the clips loose is much more than I expected. I am using a 7 gallon bucket, maybe I will try it on a 5 gallon Home Depot bucket and see if it is a little easier.
https://www.homedepot.com/p/Dustoppe...HD12/302643445
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #2 of 16 (permalink) Old 03-18-2018, 09:00 PM
hawkeye10's Avatar
First Name: Don
Doug, do you think this is as good as the Dust Deputy? It's quite a bit cheaper and that is good. Thanks for posting this. It will help a lot of us have more clean air.
DesertRatTom likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 16 (permalink) Old 03-18-2018, 10:28 PM
Doug it looks like it collected all the dust into the Dustopper can,and the Vac was clean? That is a lot more compact than the Dust Deputy, I have the same shop vac and just hate to clean the filter in it. Thanks for posting, never knew about one before.
Herb Stoops is online now
post #4 of 16 (permalink) Old 03-18-2018, 10:48 PM Thread Starter
kp91's Avatar
First Name: Doug
I can't compare to a dust deputy, but I think it lives up to the promise of catching almost all of the dust
Herb Stoops likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 16 (permalink) Old 03-19-2018, 08:31 AM
DonkeyHody's Avatar
First Name: Andy
I think you need to do more testing and report back. I like the low-profile design, and the fact that it comes ready to fit a standard bucket, and the fact that it comes with a hose to connect to the vacuum. Even if it's not quite as efficient as the dust deputy, it could still be a great alternative.
As for me, I'm already invested in a dust deputy and a shop-made 17 gallon dustbin to go under it, as well as a lot of piping and valves so mine operates like a central vacuum system. I'm totally sold on the cyclone dust separation concept. I go for months instead of hours between filter cleanings.
MEBCWD and Herb Stoops like this.
DonkeyHody is offline
post #6 of 16 (permalink) Old 03-19-2018, 10:49 AM
MEBCWD's Avatar
Doug thanks for the post. I guess this is something new they are selling. Looks like it works good. They are not available in the stores around me but they do offer free shipping to your home.
I do have a dust deputy and have been thinking about getting another one so I ordered one of these and will compare how they work. I know when I got the dust deputy I cleaned the shop vac filters and ran it for about 3 months and it still had plenty of suction. In that time I emptied the DD 3 times when it was 2/3rds full and finally thought I should check the vac. There wasn't very much dust at all on the filter. The dust was 80% to 90% fine sanding dust.
If the Home Depot unit works half as good it will be well worth the cost.
kp91 and Herb Stoops like this.
MEBCWD is online now
post #7 of 16 (permalink) Old 03-19-2018, 11:02 AM
MT Stringer's Avatar
Even with a Dust Deputy, I still have a filter bag in the Shop Vac. The filter cartridge never gets dirty. :-)
kp91, MEBCWD and Herb Stoops like this.
MT Stringer is offline
post #8 of 16 (permalink) Old 03-19-2018, 11:18 AM Thread Starter
kp91's Avatar
First Name: Doug
Mike,
I can't wait to see the side by side result. You will be the expert on this one!
I was doing my ritual cleaning last night that I do each time before I go to sea, and I sucked up leaves, wood chunks and shavings, no problem. Even though that's not what it's designed for, there doesn't seem to be any difference in the suction of the vacuum with or without it from that 'scientific' test. I didn't get much time to play with it connected to the CNC because my Z axis flex coupler broke... but that's another depressing story.
My original intent was to a cheap, small DC like the HF 1 HP that I could dedicate to the CNC (mainly for dB reasons...) but this is working well enough for now.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 16 (permalink) Old 03-19-2018, 11:47 AM
MEBCWD's Avatar
I also have the Rockler Dust Right Separator so I'll include that in the side by side comparison after I get the Dustopper.
TenGees likes this.
post #10 of 16 (permalink) Old 03-19-2018, 01:01 PM
TenGees's Avatar
First Name: Paul
Looks nice. Hope they become available in Canada too.
TenGees is offline
Makita’s BDF451 1/2 inch 18V LXT Lithium-ion Driver Drill Kit Mike Dawson Tool Reviews 4 08-10-2010 07:11 AM
Wilton 6 1/2 inch vise $9.99 @ Woodcraft Tommyt654 The Bargain Bin 0 04-27-2010 07:21 AM
Home Depot blowout sale Tommyt654 Lobby 1 01-13-2010 09:20 PM
1/4 or 1/2 inch bits? jco Router Bits - Types and Usage 30 01-11-2010 10:48 AM
1/2 inch Router Collets for Ryobi R165 Router 4Cosentinos General Routing 2 10-16-2009 08:54 PM
