CUTECH Portable Planer - Router Forums
 10Likes
  • 6 Post By Herb Stoops
  • 2 Post By Stick486
  • 1 Post By whimsofchaz
  • 1 Post By hawkeye10
post #1 of 9 (permalink) Old 03-24-2018, 03:37 AM Thread Starter
Default CUTECH Portable Planer
I just bought this CUTECH /40700HC-CT portable 12 1/2" planer and set it up the last week. I had an old Delta that ran good but the feed rollers wouldn't grab the wood and I would end up having to push the board through with a pusher stick. That is unsafe to begin with and a PITA besides.
So I spent about a month reading reviews and pricing out the different planers. I settled on the Cutech because the reviews were good, and it has a spiral cutter head with carbide cutters for less than $500., $379. to be exact + shipping
Model 40700HC-CT
They make the General International portable planer. They have several models, and combinations in each model of straight HS blades, Straight carbide blades, HS Spiral cutters, and Carbide Spiral cutters.
I bought the basic model with the Carbide Spiral cutters, I don't need all the bells and whistles on the higher priced models.
They come with a 2 year warranty, which I hope I never have to use.
The Manual was very good for setting up the planer and checking out the table, and operating the planer.
I ran a few rough sawn boards thru and they came out very smooth. I ran a maple burl through and it came out from a chainsaw rough surface to a nice even surface,but a ted rough like sandpaper,but no tearout. I haven't given it a good workout yet, but like what I have seen so far.
The best part so far too, is the noise level is less than 2/3rds of what the Delta or my old Dewalt 735 . I have it stting along side of my PC benchtop jointer and it is noticeably quieter than the jointer.
http://www.cutechtool.com/v/40700H%20ver17.03.20.pdf
Herb Stoops is online now
post #2 of 9 (permalink) Old 03-24-2018, 04:11 AM
this one??
http://www.routerforums.com/tools-wo...ch-planer.html
why didn't you go this way???
https://www.cpopowertools.com/factor...efault,pd.html
Ray Newman and Shop guy like this.
post #3 of 9 (permalink) Old 03-24-2018, 01:17 PM Thread Starter
I had one of those and they are good planers, but the noise level wouldn't be allowed where I live now.
post #4 of 9 (permalink) Old 03-24-2018, 01:21 PM Thread Starter
The replacement cutters:
Not sure if they are available elsewhere, but they will fit General,Rikon,Steelcity,Craftsman and Cutech planers. Some of those listed are currently not available, the only one I could find, General, is limited stock now.
They sell for $45./10 pack. It would take 3 packs (30ea.) to do a complete change over and have 6 ea. left over.
Part 40938
they rotate 90 deg. to make the second blade. This means that for $136. you get 2 sets of blades with 6 left over to use on the next set. So the next 2 changes you only have to order 2 packs @$90. total to complete the next 2, which means you can get 4 changes for around $56. ea. change and that is comparable to the change over of most planers with HSS cutters, and these are Carbide.
I might add that the change takes less than 5 min.( by the reviews) and is self aligning, just loosen, rotate,tighten, done. The torques wrench is furnished with the machine.
I weill also add the the HSS replacement cutters can also be used @ $30. /10 pack.
http://www.cutechtool.com/product-p/40930.htm
post #5 of 9 (permalink) Old 03-24-2018, 06:33 PM
whimsofchaz's Avatar
First Name: Chuck
Great choice Herb...I have a 735 and it is LOUD
Herb Stoops likes this.
whimsofchaz is offline
post #6 of 9 (permalink) Old 03-24-2018, 08:36 PM Thread Starter
Chuck, I found that on the 735 when I turned on the DC system it increased the noise even more than when it was running with it off. I think the airflow from the DC caused a siren effect on the cutter head.
post #7 of 9 (permalink) Old 03-24-2018, 09:20 PM
hawkeye10's Avatar
First Name: Don
Herb, I believe it will be much better than your Delta. If you don't have any snipe that would make it a great buy.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 9 (permalink) Old 05-10-2018, 10:59 AM
old coasty's Avatar
First Name: Bob
Herb,
Now that you have had it for awhile, what are your thoughts.
old coasty is offline
post #9 of 9 (permalink) Old 05-10-2018, 04:31 PM Thread Starter
Originally Posted by old coasty View Post
Herb,
I like it a lot so far,Bob, really like the lower noise level. It is very good about not sniping. I did snipe a couple of boards if I was working alone and ran a 3' long board through unsupported as it came off. I have run 8' long boards supported 4' out from planer and no snipe. 8' boards with a person on the other end, no problem. I have run up to 8' long unsupported, but ran around and off fed them myself ,no problem either. It has planed oak,poplar,maple,walnut, western cedar, aromatic cedar, alder and holly. It gives a very smooth surface,But I have noticed tiny ridges on the surface. Not very high, but can be felt and when I look closely I can detect them. Not a big deal, the ROS takes them right out in a couple of passes. I have read others that said it is characteristic of spiral cutters. The last time I used it, it filled the 32 gal. dust bin and the light went off so I had to shut it down and empty it. The chips are different looking like rat tu....rds, it kind of rolls up the chip.LOL
Did I say I really like the noise level, about the same as my router table. I can compare it to the Parks, Delta ,and the DW 735, and the Delta 15", I have had, and this is noticeably quieter.
As a related experience, Our WW club held our monthly meeting at the Seattle Central Community College Woodworking School last month.
It is a state of the art facility where they teach a 2 year curriculum in Residential, Commercial Carpentry, Wooden Boat Building, Furniture Building and Design. Each discipline is a separate course and separate shop,they call them Labs. We got a tour of all of them, and I noticed no less than 4 of these Cutech planers in amongst all the commercial machines. I asked the instructor who was giving us the tour about them, and he said they love them. They have the professional models,as mine is the basic model, but they are very similar with more fancy features.
He also said that all of the jointers,and planers have either spiral or helical cutter heads to cut down on the noise level in the shops where they have many machines running at one time.
Also noted they have a 2 year waiting list to enter their program and only graduate 60 people /year with an AS degree.
Cutech Planer KhalTom Tools and Woodworking 8 07-17-2017 09:56 AM
Cutech planer or Dewalt 735 Thrifty Tool Guy Tools and Woodworking 38 03-25-2016 10:43 AM
Keep Those Rollers On Your Planer Clean Jerry Bowen Tools and Woodworking 10 04-17-2013 06:53 PM
replacing belt delta portable planer black7jack Tools and Woodworking 0 10-15-2011 12:14 PM
Wonderful Wife (new jointer and planer) xplorx4 Tools and Woodworking 11 11-08-2009 03:29 PM
