Need suggestions for drill press vice - Router Forums
 32Likes
post #1 of 24 (permalink) Old 01-12-2019, 10:47 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
Default Need suggestions for drill press vice
Received and set up my new Shop Fox 1668 drill press. Now I'm looking for a drill press vice primarily for metal work (holes and drilling and tapping -no high-precision work) and smaller wood items.
I have clamps to secure larger wood items and a Magswitch fence jig but a nice vice would be handy.
I'd appreciate any suggestions and advice. Thanks.
Steve
sgcz75b is offline
post #2 of 24 (permalink) Old 01-12-2019, 11:02 AM
Knothead47's Avatar
I bought a machinist's vise from Harbor Freight. Photo attached.
Danman1957 and Herb Stoops like this.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
post #3 of 24 (permalink) Old 01-12-2019, 11:39 AM
CharleyL's Avatar
First Name: Charley
Mine in my wood shop is from Harbor Freight as well. It's OK for small work. I also use wooden 2 screw clamps for this.
In the metal and welding shop, which is now at my son's house across town, we have several larger drill press vises, including one that adjusts for angle drilling. They were picked up at a machine shop auction many years ago. I combined my metal working tools with his and all are now at his place. I just go there whenever I want to do any serious metal work now.
Charley
MEBCWD and Herb Stoops like this.
Central North Carolina
CharleyL is offline
post #4 of 24 (permalink) Old 01-12-2019, 12:03 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
Any size suggestions? I see 3, 4,5, and 6-inch models. My table is 12". Are any quick attaching or are through-the-table bolts/ or clamps the best method?
Thanks.
Steve
sgcz75b is offline
post #5 of 24 (permalink) Old 01-12-2019, 02:20 PM
A cross slide vise can be very handy. It allows for fine tuning where the bit will enter. Any that won't break the bank are Chinese and have a fair amount of play but some of that can be taken out by tightening the vise onto the dove tail slide more securely. There is a balance between eliminating backlash and how much effort it takes to move the jaws. They will have limited capacity. I had to attach mine to a board and then attach the board to the DP table. https://www.amazon.ca/WEN-414CV-Comp...SIN=B077QMBVTB
Another option is a cross slide table: https://www.amazon.ca/Milling-Portab...SIN=B07CZCT7TT It offers much more capacity and still offers fine tuning where the bit will touch down. The T slot table allows a lot of clamping options and you can buy hold down sets made for the table: https://www.amazon.com/HFS-Brand-CLA...Machine+Clamps These are really made for metal but they will work for wood too.
MEBCWD, Danman1957 and Herb Stoops like this.
post #6 of 24 (permalink) Old 01-12-2019, 05:09 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
Thanks for the info. I'm torn between going for a cheap one for the short term or splurging on an expensive one. Perhaps a old-style craftsman machinist will die close by the neighborhood and I can buy all his old "stuff' for a couple of hundred bucks as a favor to his widow.
Steve
sgcz75b is offline
post #7 of 24 (permalink) Old 01-12-2019, 05:24 PM
I did cheap...
total waste of money...
DaninVan likes this.
Stick486 is offline
post #8 of 24 (permalink) Old 01-12-2019, 06:59 PM
Knothead47's Avatar
I can loosen the bolts and slide front to back. I can then turn the table and center a blank or anything else under the bit or pen mill. Not a real problem. I rarely remove it as I turn a bunch of pens.
Danman1957 likes this.
John T.
post #9 of 24 (permalink) Old 01-12-2019, 08:18 PM
GO Harbor Freight !!
I have one of th 4 way Chuck showed on one DP, and a slide table like Chuck showed on a second one and a wood table and wooden fence on the woodworking DP.
I use them all a lot.
HErb
Cherryville Chuck likes this.
Herb Stoops is offline
post #10 of 24 (permalink) Old 01-13-2019, 02:49 AM
Thanks.
Steve
Clamping it down so it won't move is only one issue. You have to be able to get the spot you want to drill in the right position. So if the table or vise don't have positioning built in then I would suggest that you mount it on a board so that you can move it to where you need it and then clamp to the DP table somehow.
Herb Stoops and sgcz75b like this.
Record 52 1/2P Vice Restoration vchiarelli Show N' Tell 20 04-26-2018 01:00 AM
Suggestions for a new bench please darsev Workshop Showroom 32 11-17-2014 05:43 AM
thinning the drill press heard with a 120 volt VFD tool613 Tools and Woodworking 9 04-18-2013 08:15 AM
Attaching a vice to a bench rail?? matt1710 Tools and Woodworking 10 09-24-2010 10:20 AM
Best drill press vice Birchwood Tools and Woodworking 1 07-16-2005 12:10 AM
