Recommendations for 4" dust collector flexible hose - Router Forums
 27Likes
  • 5 Post By Stick486
  • 6 Post By Herb Stoops
  • 6 Post By difalkner
  • 2 Post By Herb Stoops
  • 2 Post By Stick486
  • 3 Post By DesertRatTom
  • 2 Post By sreilly
  • 1 Post By Stick486
post #1 of 9 (permalink) Old 04-26-2020, 09:26 PM Thread Starter
Ed3443's Avatar
First Name: Ed
Default Recommendations for 4" dust collector flexible hose
Hi Guys,
I am looking for recommendations for 4" flexible hose for a dust collector. Looking for only 10 feet. Thanks.
Ed3443 is offline
post #2 of 9 (permalink) Old 04-26-2020, 09:51 PM
Woodcraft...
Made in America...
anti-static too...
top shelf for interior smoothness, great temperature range, superb flexibility, wear, and longevity...
https://www.woodcraft.com/products/f...-hose-flexaust
the light duty is junk...
LeeValley...
https://www.leevalley.com/en-us/shop...ollection-hose
post #3 of 9 (permalink) Old 04-26-2020, 10:00 PM
Rockler also has it. Don't get fooled into buying the black flex drain pipe that the big box stores sell,the corregations will collect dust.and also reduce airflow.
https://www.amazon.com/Vacuum-26-Dus...ode=8106801011
Herb Stoops is online now
post #4 of 9 (permalink) Old 04-26-2020, 10:01 PM
difalkner's Avatar
First Name: David
I bought two of these and they've worked fine for daily use for the last 3 years - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This may be in Stick's 'junk' category but they feel plenty thick and sturdy to me, and like I said, I move them around to different machines every day multiple times - no issues. These are 20' long, though, and I don't know if they have shorter lengths.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #5 of 9 (permalink) Old 04-26-2020, 10:15 PM
David
Those are good ones,David, and reasonable price too. They can be cut to length if need be.
difalkner and Ed3443 like this.
post #6 of 9 (permalink) Old 04-26-2020, 10:31 PM
David
the junk one is at Woodcraft - the light duty one...
post #7 of 9 (permalink) Old 04-27-2020, 01:00 AM
Rockler. Their stuff fits together and no other parts are interchangable. 4 inches ain't four inches anywhere. No standards for inside, outside dimensions. Since I stopped even trying to match different brands, dust collection has become much easier. I only use Rockler parts now and have no idea if any other brands are OK.
I have had a Rockler 4 inch by 23 foot collapsable hose for at least 10 years and it's holding up nicely. It has a metal coil so you can ground it if you want. Consider that an endorsement.
Ed3443, Herb Stoops and sreilly like this.
DesertRatTom is online now
post #8 of 9 (permalink) Old 04-27-2020, 07:44 AM
sreilly's Avatar
First Name: Steve
That would be fine but they and many others have little to nothing for 6" systems. When reducing down it's easier but 6" fittings for my main CV1800 was a royal pain and you want to stay at 6" as long as you can before connection to the equipment. But again the fitting of the adapters to the hoses can be a challenge at best sometimes so if you already have fittings and hose take some with you if going in store and test the fit if you can. One item I have found to be priceless is Fernco couplings which come in a variety of sizes and reducer sizes.
Nickp and Herb Stoops like this.
sreilly is offline
post #9 of 9 (permalink) Old 04-27-2020, 08:03 AM
so go all metal, (snaplok or the like) and make your own fittings right down to the blast gates...
components are easier to find, way more adaptable, cheaper than PVC, nothing's proprietary, and the biggest plus - extensive static control...
DIY branch taps/wyes, about 3$... how much is a 6'' wye in PVC??? or 6x6x4??
need to modify, change or update.. everything you used is reusable o near zero waste..
try that w/ a 6'' wye...
difalkner likes this.
