Harbor Freight 10 piece template guide set - Router Forums
post #1 of 5 (permalink) Old 06-28-2009, 04:24 PM Thread Starter
First Name: Bob
Default Harbor Freight 10 piece template guide set
I purchased this item at my local HF store for ~$20.00 (comparable sets cost $40 at Rockler(on sale at $30) and $44 at Woodcraft). The construction is solid brass and the set comes packed in a plastic case. The hinge on the case is somewhat flimsy and I wouldn't expect it to last. It contains an adapter, 7 template guides and 2 knurled lock nuts. After purchasing I tried the lock nuts on all the template guides and all fit smoothly, with the exception of some minor roughness on the smallest template guide. I think it will probably work itself smooth through use.
A visual inspection revealed no discernable lack of concentricity between the bores of the guides and the threaded diameters, however I have no way to check this any closer than by visual inspection. The ID and OD of the guide are stamped on each one, but the stamping is superficial and a little bit hard to read if not in good light.
My initial impression is that this set represents good value for the money and my initial rating is 9 on a 10 point scale. A better quality case would move the rating up as would a better fit on the one guide that was a little rough and deeper engraving of the size. Here is a link to the set on the HF website:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
rstermer
rstermer is offline
post #2 of 5 (permalink) Old 06-28-2009, 05:17 PM
Hi rstermer
Put the plastic shipping box in the trash can and make a box with a lid to keep them nice and safe in
rstermer
post #3 of 5 (permalink) Old 06-28-2009, 07:30 PM Thread Starter
First Name: Bob
Hi rstermer
Hi Bob- You've got a ton of 'em. What are those rings that look like they are made out of mdf and are sitting outside the box?
rstermer
rstermer is offline
post #4 of 5 (permalink) Old 06-28-2009, 08:56 PM
Hi rstermer
Some are offset rings and some are made so I can use the brass guides in my steel router mounting base plate on one of my router tables..
rstermer
post #5 of 5 (permalink) Old 06-29-2009, 06:29 AM
i bought a porter cable steel guide set before i knew any better then realized it didnt have a 1" guide so i bought a HF set, not the one you got though, i got the one without a case for like $12. probably the same guides im sure but anyways they seem to work great and have the 1" guide i was looking for
Mike Gager is offline
Workout the offset for a template guide opelblues Guide Bushings and Templates 5 04-29-2009 11:44 AM
Harbor Freight 10 Piece Router Template Guide Set rstermer Guide Bushings and Templates 4 06-04-2008 05:56 PM
Template Guide sizes TWheels Guide Bushings and Templates 11 06-04-2008 05:35 PM
Make a template to create a filler piece? Ric Naff Jigs and Fixtures 3 01-12-2006 07:56 PM
Template Guide depth ttait General Routing 3 10-03-2004 05:16 PM
