Planer Thicknessers - Router Forums
post #1 of 26 (permalink) Old 09-05-2009, 05:39 PM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default Planer Thicknessers
Does anyone have any views on portable planer thicknessers, please? DeWalt look quite good although some of the imports seem a lot less.
If I went for a secondhand DW would it be a better bet than a new import?
Any thoughts welcomed !
Cheers
Peter
istracpsboss is offline
post #2 of 26 (permalink) Old 09-05-2009, 06:37 PM
curiousgeorge's Avatar
First Name: George
I have the DW735 and like it very much. The 735 seems to be the best of all the so called portable planers as far as in the mag. comparisons. I would really love to have the "spiral" cutter heads that Grizzly sells, but can't afford the upgrade right now.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #3 of 26 (permalink) Old 09-05-2009, 07:38 PM
AxlMyk's Avatar
DW735. No doubt about it.
AxlMyk is offline
post #4 of 26 (permalink) Old 09-05-2009, 08:24 PM
allthunbs's Avatar
First Name: Ron
Cheers
Peter
Hi Peter:
I have the SteelCity 13". Snipe is driving me nuts. In all fairness though, I plane a lot of softwoods and the planer could be setup for hardwoods. But, when I went to the supplier and compared the machines, the DW735 was a different colour and a few things moved around a bit but it was identical to the 12.5/13" SteelCity/Delta/Jet/Grizzly/King/Ridgid and a bunch of other brands. I haven't been able to track the manufacturer but I'm sure it is in Taiwan somewhere. No matter how carefully I study these planers, none seem to be snipe-free. It is only when you go to the heavier machines that things _might_ get better.
I've even replaced the in and out-feed tables and the planer table with no improvement.
I've been trying to find instructions on how to adjust roller pressure and other adjustable aspects of these planers to no avail.
There is something that you should consider. The SteelCity philosophy is to offer identical product to the Delta but with a few additional features. You might explore what is available in your area.
Good luck. I hope this gives you a bit of insight.
Allthunbs
allthunbs is offline
post #5 of 26 (permalink) Old 09-05-2009, 08:28 PM
AxlMyk's Avatar
Umm, how is the DW735 identical to the others? It's a one-of-a-kind design.
http://www.dewalt.com//ProductImages.../7/DW735_1.jpg
http://www.steelcitytoolworks.com/pr...00_closeup.jpg
Perhaps you're thinking of the DW734.
http://www.dewalt.com//ProductImages.../7/DW734_1.jpg
AxlMyk is offline
post #6 of 26 (permalink) Old 09-05-2009, 09:18 PM
Glenmore's Avatar
First Name: Glenmore
Pete I have one of the older models DW 733 and I love it. I know that the 734 is another great one and the 735 if the catilac of all Dewalt thicknessers.
Glenmore
Mountain Top PA
Glenmore is offline
post #7 of 26 (permalink) Old 09-05-2009, 11:26 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I've had a Delta 12.5" for about nine years and am completely happy with it, set up correctly, there is no snipe and the double edged blades take only a few minutes to change and are self positioning,so no fiddling is involved.
Harry
harrysin is offline
post #8 of 26 (permalink) Old 09-05-2009, 11:32 PM
RMilgie's Avatar
First Name: Rob
I have the Dewalt 735 and absolutely love it. I would highly recommend it> I purchased the Wixey thickness gage and it is also awesome
http://www.wixey.com/planer/images/top510_02.jpg
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."
Thomas Jefferson
RMilgie is offline
post #9 of 26 (permalink) Old 09-06-2009, 12:04 AM
RustyW's Avatar
First Name: Rusty
Peter, the advantage of the DeWalt 734 and 735, is the cutterhead lock. I believe one of the Delta portables also has this feature. This keeps the head from "jumping" as the stock enters and exits. I had the cheap ($240) Delta, and had to run stock 8" longer than needed. Because I had to cut 4" off each end when done. Now with the 734 I get no snipe at all. I have an issue of Wood magazine where they tested portable planers. They actually rated the 734 as having less snipe than the 735. Only because they test them as they come out of the box. The 734 comes with large in and outfeed tables. With the 735 they have to be purchased separately, so they tested without.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #10 of 26 (permalink) Old 09-06-2009, 03:46 AM Thread Starter
Country: Croatia
First Name: Peter
Thanks guys. It's a 733 that I'm looking at. It seems to have resharpenable blades and was made in Italy. Rusty's comment about the infeed and outfeed tables being an extra may be an issue. The 733S seems to come with them as well as a stand.
Cheers
Peter
Planer Jigs.... challagan Tools and Woodworking 8 04-05-2013 10:52 PM
used planer reikimaster Tools and Woodworking 19 04-22-2012 02:12 AM
Wonderful Wife (new jointer and planer) xplorx4 Tools and Woodworking 11 11-08-2009 03:29 PM
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-21-2007 11:13 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
