Harbor Freight Router Inlay Kit - Router Forums
post #1 of 2 (permalink) Old 01-16-2012, 10:32 AM Thread Starter
First Name: N/A
Default Harbor Freight Router Inlay Kit
The Harbor Freight Router Inlay Kit was purchased while visiting relatives to do some inlay work. I purchased it because it was readily available at a local Harbor Freight store and it was only $9.99. The kit included guide bushings and a router bit.
The bit broke before we finished cutting out the recess. A replacement bit was purchased at a box store and the project finally completed. We never found the part of the bit that broke off.
The guide bushings worked very well and the project turned out nice.
Be advised if you purchase this item you should trash the bit and get a good bit from the start. Call me a weenie but I don't like to be around routers when bits start breaking!!
Pine Cone is offline
post #2 of 2 (permalink) Old 01-16-2012, 10:40 AM
HI
You just need to use a bigger diam. bit..(1/8" to 3/8") can be used for inlay work.
Making an Inlay and Inset Drawer Pull learnexperience General Routing 0 10-31-2011 06:48 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
another kit or a dedicated table router? rprice54 General Routing 11 08-06-2009 07:51 AM
