Mag-DRO Miter Slot Caliper Base - Router Forums
post #1 of 2 (permalink) Old 07-29-2012, 02:11 PM Thread Starter
GulfcoastGuy's Avatar
First Name: Patrick
Default Mag-DRO Miter Slot Caliper Base
I wanted to check the sizing of the pieces I milled so I bought a cheap six inch digital caliper from HF. I also wanted a way to really tune in my tools. While browsing the Newwoodworker.com I saw his review of the Mag-DRO caliper bases. Check them out Here.
Mag-Dro Home
The miter slot base was on Amazon for less than $10 with free shipping. With it you can do accurate, repeatable checks on the table saw alignment of blade to slot and fence to slot. You can also use it as a component in other measurement jigs. It came in on Thursday but I didn't get to check it out till last night. It works well. I'd go into more detail but I'd just be parroting the review on New Woodworker. If you have calipers, either digital or rotary, it's an inexpensive path to very accurate tool setups.
MAG-DRO™ Caliper Bases - NewWoodworker.com LLC
GCG
GulfcoastGuy is offline
post #2 of 2 (permalink) Old 07-30-2012, 01:07 PM
I use the Miter Slot base!
johno1946 is offline
Miter Slot? Denco Table-mounted Routing 15 06-11-2012 11:32 AM
Bit for cutting slot for Miter Track Racer2007 Table-mounted Routing 4 08-31-2011 11:01 PM
miter slot necessary? dgave Table-mounted Routing 25 07-09-2011 12:12 PM
Distance from palte to miter slot? smboudreaux Project Plans and How To 2 06-29-2011 05:13 AM
Do you use your miter slot for sleds, etc? BigJimAK Shop Safety 6 03-19-2010 02:30 PM
