Bench Top Drill Press - Router Forums
post #1 of 6 (permalink) Old 01-08-2013, 07:53 PM Thread Starter
CGL
First Name: Chris
Default Bench Top Drill Press
Good evening, has anyone had any luck with Harbor Freight 5 Speed Bench Drill Press item #60238? I am running out of space and I would like a small drill press. I am not a machinist so I believe a 5 speed should suffice. I have read reviews on other drill presses but it seems only the mad customers leave reviews. Thanks, Chris
CGL is offline
post #2 of 6 (permalink) Old 01-08-2013, 08:34 PM
IC31's Avatar
First Name: Dave W
I can't directly answer about the 5 speed as I have the heavy duty benchtop 16 speed. It was a good purchase for me and have 'pushed' the dickens out of it, including some heavy steel drilling today. I've had it probably 15 years with no real problems. While there are some minor differences, this HF/Central Machinery DP has been sold under several names including Delta.
One problem that I did have - the chuck had significant runout(.060 plus) and was replaced with a JET brand which has none. These are #2 Morse Taper installed chucks, so an easy change out These DP will crack the table height adjuster if you overtighten.
I strongly suggest something bigger then the 5 speed as well as one that has a key type chuck - it's amazing how fast you discover a small DP just wont do the job
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is offline
post #3 of 6 (permalink) Old 01-09-2013, 06:28 AM
me5269's Avatar
First Name: Michael
Send a message via AIM to me5269
I agree with Dave. I had a HF 5 speed for over 9 yrs and had no problems with it. I found I needed slower speeds so I upgraded it to the 12 speed, 44836, about a year ago. Have had no problems with this one either. If you get HF coupons, there is one often for $99 for this DP. Well the extra $30.
me5269 is offline
post #4 of 6 (permalink) Old 01-09-2013, 10:53 AM
JOAT's Avatar
First Name: Theo
I've got two of the little buggers. One from about 1996/7; a week after I got it, needed a new switch, which ran about $5 at Lowes. Still going strong. Got the other, I don't know, maybe a year or two ago, working fine. Neither has any visible runout. The newer one will eventually wind up in my spare room in the house, where I'm trying to assemble a small shop for some of my work that is more convenient for me - like having a toilet just a few steps away. And I happen to like key chucks.
JOAT is offline
post #5 of 6 (permalink) Old 01-14-2013, 04:02 PM
First Name: Ted
HFT has great equipment and I've never had a problem that couldn't be resolved easily. I own the older 5 speed DP and its been awesome since day one. I bought it over 20 yrs. ago when I started building a workshop. I've upgraded DPs over time as need required, and plan to keep them all. HFT tools are perfect for me.
tediam is offline
post #6 of 6 (permalink) Old 01-15-2013, 06:08 AM
me5269's Avatar
First Name: Michael
FYI, The March issue of Wood Magazine has a HF coupon for the 44836 12spd DP for $99 ($70 off).
me5269 is offline
Benchtop Drill Press Modification JimS Tools and Woodworking 23 07-19-2018 12:51 PM
Drill 12 inch bench drill press 152.219110 kp91 Craftsman Manuals 0 03-22-2011 08:30 PM
radial drill press experiences pls. allthunbs Tools and Woodworking 6 07-03-2010 06:08 AM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
