Dust Deputy Cyclone - Router Forums
post #1 of 4 (permalink) Old 04-04-2013, 02:14 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Default Dust Deputy Cyclone
This was lightly touched on elsewhere but is deserving of more details.
First, I give this unit five out of five stars, or ten out of ten, if you prefer. I bought my metal version of the Dust Deputy five or six years ago and it, immediately, became an indispensable part of my tool collection.
Just before I bought it, I was working a cedar siding refinishing job. I was trying to collect as much dust, when removing the old finish, as reasonably possible.
Initially, I used my pretty powerful, large capacity shop vac. However, it would start losing suction after only a few minuets of collecting the dust from running my surface removal tool. In less than fifteen minutes, it was time to clean the filter.
I knew I need a prefilter of some sort, so I built one from a 30 gal plastic barrel. The vacuum drew from the top and the working end dumped into the bottom, which had about twelve inches of water and a 3-M scrub pad, to act as a baffle. It worked, but even the water got messy quick. And boy would that thing foam!
Looking around to address the problem in the future, I learned about cyclones. I found the Dust Deputy and took a $200.00 chance. It worked. So well, in fact, I was able to abandon the large vac and go to a small, high powered one. Since the tub no longer had to hold what was being vacuumed, a more portable unit was fine. Too, because only a small amount of dust got to the actual filter, suction remained high for around an hour or so, so a less powerful vacuum worked better than the large one did without the cyclone.
When vacuuming drywall dust, this little cyclone is an absolute must. Actually, it's a must most of the time. Since I bought it, my vac rarely runs without it. I liked it so much, I bought Oneida's 3hp Dust Gorilla, but that's another review.
P.S. I am now considering their Super Dust Deputy for my 1-1/2hp Jet system.
Name:	Dust Deputy.jpg
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #2 of 4 (permalink) Old 04-04-2013, 03:15 PM
During the course of our 3+ hp router comparison testing we will be evaluating the Dust Deputy Deluxe, Clear Vue Cyclones CV06 and Rocklers Dust-Right seperators. They all work but a review of these models may help forum members with their purchasing decision.
post #3 of 4 (permalink) Old 05-19-2014, 11:44 AM Thread Starter
Dejure's Avatar
First Name: Kelly
My Rocklers Dust-Right Separator has been sitting in the shop waiting for me to run a craigslist add to give it away. That is only because it was replaced by the Super Dust Deputy.
The Separator makes more sense than the small Dust Deputy, or its equivalent, when running actual dust collectors. The Deputies are for small, vacuum hoses and would restrict flow too much on a collector.
The Separator does what it's supposed to do, but does little to nothing for fine dust.
It, also, knocks the draw down significantly, however, because it takes four inch hoses, would be a better bet for collectors.
Scraps are a myth.
Dejure is offline
post #4 of 4 (permalink) Old 06-16-2014, 08:46 PM
papawd's Avatar
First Name: warren
+1 for Dust Deputy, I have it hooked to a good ShopVac With Hepa Filter on shop vac and no dust escapes. Avery good product that actually does what it says it will do. Also it is Made in America something rare these days
papawd is offline
Cyclone dust collectors TomB19 Tools and Woodworking 7 11-13-2012 08:15 PM
Finally! A Dust Deputy Cart curiousgeorge Show N' Tell 15 07-31-2012 02:34 PM
Dust Deputy rwl7532 Tools and Woodworking 19 07-05-2012 02:32 PM
Dust Deputy Cart jpstewart New Member Introductions 6 02-21-2011 07:31 PM
