Product Review - Oshlun 6" Dado Stack - Router Forums
post #1 of 19 (permalink) Old 06-08-2013, 11:32 PM Thread Starter
GulfcoastGuy's Avatar
First Name: Patrick
Default Product Review - Oshlun 6" Dado Stack
I've been wanting a dado stack since I bought my Table Saw but I haven't had a need and with my budget - no need = no toy ... till now.
The wife wanted some end tables and she showed me a picture of a table made to look like a boat dock and asked .. could I? Of course I answered yes, but the design required a dado stack. I already had the Oshlun 6" picked out so I pulled the trigger.
[IMG] IMAG0123 by pat w1, on Flickr[/IMG]
Oshlun SDS-0630 6-Inch 30 Tooth Stack Dado Set with 5/8-Inch Arbor - Amazon.com
I needed the 6" because the TS manual (Ridgid 4510) specified that size due to the power of the saw.
I liked the idea of full sized chippers as opposed to the two tooth cut down chippers on some of the other sets I researched. As the box shows there are [email protected]/8", and 1 each @3/32" and 1/16" along with 8 shims; 2 each @ .005",.010," .015", and .020". All this came in a cardboard box with decent foam packing separating the main cutters from each other and the un-separated stack of chippers. The shims were in a separate plastic bag under the top piece of foam. It should be noted that some of the Oshlun dado stacks purchased through Amazon have recently been shipped in a much nicer aluminum case. That apparently has been discontinued. I was aware of this before I placed my order and am only slightly disappointed. I'll probably build something to store the stack.
The individual main blades and chippers have a very nice heft, meaty carbides and appear nicely made with what seems to be a good amount of attention to quality control. Each of the chippers is clearly marked showing its thickness. This is carried over on the shims. Both markings appear to be printed, not stamped, but it wasn't effected by wiping them down with WD40 for rust protection. The shims were stamp cut and still have some of the edge roll that comes with that process so it is clear that other than the print work no post processing was done and a sharp edge is on the inner and outer edges. I'll have to be careful not to run my fingers along them or I may be cut.
[IMG] IMAG0117 by pat w1, on Flickr[/IMG]
[IMG] IMAG0119 by pat w1, on Flickr[/IMG]
The cut quality of the set was very acceptable too me, being a hobbyist. The side cuts were very smooth and the bottoms were cleanly cut with only a very thin indication of where one cutter is separated from another.
[IMG] IMAG0120 by pat w1, on Flickr[/IMG]
[IMG] IMAG0121 by pat w1, on Flickr[/IMG]
There was a small amount of tear out on the back side of the cut with no backer but with the ZCI the tops were cleanly cut and looked very nice.
Overall I'm pleased with the set and expect it to perform well for my purposes for a long time.
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #2 of 19 (permalink) Old 06-09-2013, 07:41 AM
Gene Howe's Avatar
First Name: Gene
Really nice review of a good product.
As a user of an 8" dado set, (Not Oshlun) I can assure you that you will, in all likely hood, never need more than a 6".
It looks like you are getting nice, flat cuts. I had to have mine reground because I was getting "bat ears" on each side of the cut. Not good for cutting box joints or any other exposed joint.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 19 (permalink) Old 06-09-2013, 08:36 AM
Like Oshlun blades a lot, first project to try out a new dado set was a case to replace the cardboard one it shipped in.
TomE is offline
post #4 of 19 (permalink) Old 06-09-2013, 08:46 AM
Gene Howe's Avatar
First Name: Gene
Nice box, Tom.
Gene Howe
Snowflake, AZ
post #5 of 19 (permalink) Old 06-09-2013, 08:48 AM
Nicely done review Patrick. Guys, please upload your photos directly onto the forums so they will always be available.
post #6 of 19 (permalink) Old 06-09-2013, 09:34 AM
Forgot to mention, nice write up Patrick
Originally Posted by Gene Howe View Post
Nice box, Tom.
Very utilitarian, looks like some leftover birch ply and underlayment, if you look closely it seems that I was a bit indecisive on which way to mount the hinge judging by the hole pattern at the bottom edge of the lid and the mounting of the cut chart is classic.
TomE is offline
post #7 of 19 (permalink) Old 06-09-2013, 09:53 AM
Gene Howe's Avatar
First Name: Gene
Hey, Serves the purpose, right?
Gene Howe
Snowflake, AZ
post #8 of 19 (permalink) Old 06-09-2013, 10:00 AM
Good review Patrick. Like Gene, my old Sears stack leaves bat ears which can be really annoying to look at so one of the first things I want to know is whether they will produce a flat bottom.
post #9 of 19 (permalink) Old 06-09-2013, 10:22 AM
Gaffboat's Avatar
First Name: Oliver
Excellent review! Thanks Patrick.
Gaffboat is offline
post #10 of 19 (permalink) Old 06-09-2013, 10:53 AM Thread Starter
First Name: Patrick
Attachment 62239
Yup, Exactly what I have in mind ... end tables first, then the completion of the DIY Katie dovetail, the bandsaw tension gage, gotta finish a aquarium sump in there somewhere, too
Mike, I'm with you on this but all my photos are on my Flickr account and unless Yahoo drops Flickr I think I'm good.
GCG
___
___
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 5 01-18-2020 09:11 AM
Product Review - Trend's Tool and Bit Cleaner. N'awlins77 Tools and Woodworking 12 07-04-2013 02:17 AM
8" STack Dado set Dmeadows The Bargain Bin 0 10-15-2012 09:02 AM
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 10:35 PM
Product review: HF Rechargeable Worklight Cochese The Bargain Bin 3 03-03-2010 07:09 PM
