ND Vibra-Tite - Router Forums
post #1 of 8 (permalink) Old 07-25-2013, 10:28 PM Thread Starter
Default ND Vibra-Tite
A question that keeps coming up on the forums is how to make the leveling screws on mounting plates stay put. There are several solutions to this but the method I prefer is to use ND Vibra-Tite. Apply it to the threads, let it dry for a couple minutes and assemble. It reaches a full lock in 24 hours. Here is the advantage over other thread lockers: you can easily loosen the screws, remove/replace them and in 24 hours it re locks. Another application is when you are using an acrylic sub base plate; if you over tighten the screws it will crack. With Vibra-Tite on the threads all you need to do is snug the screws and they will lock in position.
This product sells for about $20 for a one ounce bottle but it lasts for ages. My bottle shown was purchased in 1995 and it works like day one, still about 3/4" left in the bottle. This product is now sold as ND Vibra-Tite VC-3. Here is a link for more information:
Vibra-Tite | Vibra-Tite VC-3 Threadmate
Note: You can order from Amazon
post #2 of 8 (permalink) Old 07-26-2013, 02:31 AM
Not aware of that brand, Mike.
In Australia, I have heard of Loctite.
Loctite - Henkel
Sydney, Australia
jw2170 is offline
post #3 of 8 (permalink) Old 07-26-2013, 06:33 AM Thread Starter
Not the same stuff James. I have searched Loctite's product list and they still do not offer a similar product. Loctite was developed in the US; used their products many times.
post #4 of 8 (permalink) Old 07-26-2013, 06:42 AM
tvman44's Avatar
First Name: Bob
I normally use the Blue Locktite because it is removable, may have to try to find some ND Vibratite just to compare even thou I am happy with Blue Locktite.
tvman44 is offline
post #5 of 8 (permalink) Old 07-26-2013, 07:45 AM
GulfcoastGuy's Avatar
First Name: Patrick
Thanks for the tip. How long is the usable life once applied?
BTW for those not familiar with Loctite thread lockers, stay clear of the Red and Purple variants unless you need a PERMANENT hold. They need heat (as in propane torch heat) to break the threads free. And Mike is right, once broken you'll need to reapply.
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #6 of 8 (permalink) Old 07-26-2013, 07:57 AM
First Name: Paul
I've used ND Vibratite Type 3 (old name) on screws deep inside tools where I don't want them working loose from vibration. As Mike shows in his photo, it is applied to the threads and allowed to dry BEFORE assembly.
I liked the fact that I could apply it to the screws or bolts and set them aside for days or weeks before installing.
I'm glad Amazon now carries it. Previously it was devilishly hard to find.
An excellent product!
PRDarnell is offline
post #7 of 8 (permalink) Old 07-26-2013, 08:35 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
Did you ever find out if the small tube could be mailed?
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
post #8 of 8 (permalink) Old 02-14-2014, 09:04 PM
Default Vibra-Tite Products
Mike, goto ActionGear.Com.Au Click on the link on the right where it says Vibra-Tite and you will see a pretty good range their of the product range from thread lockers to anti-size products. Hope this helps
[QUOTE=jw2170;345029]Not aware of that brand, Mike.
Bolinger is offline
