Another glue question - Router Forums
 9Likes
  • 4 Post By Semipro
  • 3 Post By JOAT
  • 1 Post By honesttjohn
  • 1 Post By DesertRatTom
post #1 of 9 (permalink) Old 08-29-2016, 07:39 PM Thread Starter
Default Another glue question
Gotta make the grandson something for when we go see him next month. Looking at a truck he can use and abuse. Too young for a train yet - that's coming down the road.
If I cut all the parts out - can I paint them before I glue and clamp them all together? Or do I have to glue the raw wood (probably maple) parts together first and hope the paint job doesn't look too awful bad? Or, instead of paint, I could just assemble it and use the 50-50 glue mix for a finish.
HJ
honesttjohn is online now
post #2 of 9 (permalink) Old 08-29-2016, 08:32 PM
Semipro's Avatar
First Name: John_*
you never get a good adhesion gluing painted products together,glue stick to the paint does not stick to the wood.
Semipro is online now
post #3 of 9 (permalink) Old 08-29-2016, 11:15 PM
JOAT's Avatar
First Name: Theo
Originally Posted by honesttjohn View Post
If I cut all the parts out - can I paint them before I glue and clamp them all together? Or do I have to glue the raw (probably maple) parts together first and hope the paint job doesn't look too awful bad? Or, instead of paint, I could just assemble it and use the 50-50 glue mix for a finish.
Well, you could actually paint them first. IF you taped off the areas to be glued, so you're gluing raw wood. Or, you could glue them, then tape off the areas you want different colors, and that should work. Or, you could just use the 50/50 glue mix - I have found that magic markers work well on that, so you could color it that way, again with taping. OR, you could leave the wood unfinished, and let him decorate it himself, if he so desires. Surprised me a bit, my grandson has left his monster truck bank undecorated, especially since the kid is pretty darn talented for just turning 7. Or, you could glue it together, then paint it all the same color - or camoflague it. The possibilities are many, and he will probably like it regardless of how you do it.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #4 of 9 (permalink) Old 08-29-2016, 11:28 PM Thread Starter
He's only 18 months old so I gotta give him a finished product. But this will give me someting to think about.
Thanx
HJ
MT Stringer likes this.
post #5 of 9 (permalink) Old 08-30-2016, 12:48 AM
Glue the thing together first. Select a base color, say yellow, and paint the whole finished truck that color, then tape off anything you want to paint a different color. Cover the whole thing with glossy finish.
honesttjohn likes this.
DesertRatTom is online now
post #6 of 9 (permalink) Old 08-30-2016, 01:05 AM
John I can also suggest using SamaN stains. They are water based so they would have no effect on the adhesion of the glue over layer and could also probably be mixed with the glue if desired. Best stains I have ever used by far. SamaN - Water-based stain - Products - [SamaN Canada] Look at the premixed stains and then the 128 color chart.
post #7 of 9 (permalink) Old 08-30-2016, 09:18 AM Thread Starter
So you're saying a water based stain will not affect the glue. What about water based paint?
HJ
post #8 of 9 (permalink) Old 08-30-2016, 09:21 AM Thread Starter
That sounds like the most practical. It's not like this is gonna be a masterpiece to display. It's for a kid to use and abuse.
HJ
post #9 of 9 (permalink) Old 08-30-2016, 12:07 PM
John I wouldn't think water based paint mixed with glue would be a problem as far as adhesion goes. The paint itself has some adhesive properties. However dried paint would if you glued over it and I don't think the paint will penetrate like the glue does so the paint's bond would be inferior by comparison.
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 11:21 AM
Router Table Top Glue Matthew C Smith Table-mounted Routing 18 05-03-2014 11:06 PM
DC Question angus Lobby 3 03-31-2008 08:29 PM
