Metal Cutting Blade For Miter Saw - Router Forums
 5Likes
  • 1 Post By Stick486
  • 1 Post By Tagwatts
  • 2 Post By Gaffboat
  • 1 Post By Cherryville Chuck
post #1 of 9 (permalink) Old 09-02-2016, 08:05 AM Thread Starter
Contributor of the Month
Default Metal Cutting Blade For Miter Saw
I have to cut some aluminum for a storm window and would like to do it on the miter saw as I would like a clean 45 degree cut. In the past I have cut aluminum with a jig saw or recip saw but this piece is only an inch wide and I want the cut clean and accurate. What blades do you folks recommend for miter saw metal cutting?
Thank You.
JIMMIEM is offline
post #2 of 9 (permalink) Old 09-02-2016, 08:30 AM
paduke's Avatar
I cut thin (under a 1/4") aluminum on my miter saw with a miter saw blade. The rake on a miter saw teeth is not as aggressive as a regular cross cut blade. You can also try reversing any carbide tip saw blade if you do not have a miter saw blade.
paduke is offline
post #3 of 9 (permalink) Old 09-02-2016, 10:53 AM
this will do you right..
Freud D1080N Diablo 10-Inch 80 Tooth TCG Non-Ferrous Metal...
to do better go w. a LU90...
and I like my Freud...
TWheels likes this.
post #4 of 9 (permalink) Old 09-02-2016, 12:09 PM
I've also cut 1/8th aluminum bar using the 80 tooth Freud. Makes a very clean cut. Most blades will cut really thin aluminum stock, but I'd avoid one with a really aggressive rake to the teeth. You might want to back it with some scrap wood.
post #5 of 9 (permalink) Old 09-02-2016, 12:15 PM
high tooth count triple chip in NEGATIVE rake is what you want...
post #6 of 9 (permalink) Old 09-04-2016, 03:44 PM
First Name: frank
I just wanted to say, it is really amazing to me the amount of knowledge that is available on this forum if you just ask. For me this so great, as old as I am, and just starting in the woodworking areas. I am impressed. I want to say thank you to all of those who are willing to impart with their knowledge in an attempt to help us less fortunate individuals.
honesttjohn likes this.
Tagwatts is offline
post #7 of 9 (permalink) Old 09-04-2016, 06:07 PM
You mean us grumpy old farts are good for something????
HJ
honesttjohn is offline
post #8 of 9 (permalink) Old 09-04-2016, 06:38 PM
Gaffboat's Avatar
First Name: Oliver
HJ
Yep. If nothing else we can serve as a bad example. Meanwhile, the older and grumpier we get, the better stories we tell.
Stick486 and David Dickson like this.
Gaffboat is offline
post #9 of 9 (permalink) Old 09-05-2016, 02:30 PM
The best way to improve the human condition is to build a storehouse of knowledge and make it freely available.
TWheels likes this.
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 12:11 PM
advice on specific hole cutting in metal needed... rpludwig General Routing 23 01-14-2014 05:31 PM
Freud glue line rip blade troubles - table saw phillipdanbury Tools and Woodworking 5 08-25-2013 10:19 PM
Learning More About My New Band Saw Jerry Bowen Tools and Woodworking 32 10-05-2012 03:46 PM
Question about saw blades. N'awlins77 Tools and Woodworking 21 03-21-2011 08:47 PM
