Drilling a curved hole - Router Forums
 13Likes
post #1 of 12 (permalink) Old 09-05-2016, 04:09 PM Thread Starter
chessnut2's Avatar
Default Drilling a curved hole
I don't think I've ever needed to do this, but it's interesting to watch:
Gaffboat, TenGees, Nickp and 2 others like this.
chessnut2 is online now
post #2 of 12 (permalink) Old 09-05-2016, 09:14 PM
That was swell. Now, what the heck would you use that for?
DesertRatTom is online now
post #3 of 12 (permalink) Old 09-05-2016, 11:26 PM
First Name: Ray
Desert Rat Tom: looks like a solution in search of a problem??.....
TWheels, Nickp and RainMan 2.0 like this.
Ray Newman is online now
post #4 of 12 (permalink) Old 09-05-2016, 11:48 PM
RainMan 2.0's Avatar
Good one Ray
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 12 (permalink) Old 09-06-2016, 03:07 AM
wire chases/pulling wires through wall inside corners...
TenGees and RainMan 2.0 like this.
post #6 of 12 (permalink) Old 09-06-2016, 07:27 AM
CharleyL's Avatar
First Name: Charley
As an electrician (many years ago) I needed one of those on two different occasions. In both cases, I was trying to get wires from the wall into the ceiling and there was a double joist sitting right on top of the wall. For both I ended up chopping out a lot of wood and sheet rock that wouldn't have been necessary if I had one of these, but there's no point in me making one now. It's been almost 50 years since the last time I needed it. I now leave that kind of work to younger guys.
Charley
Central North Carolina
CharleyL is offline
post #7 of 12 (permalink) Old 09-06-2016, 07:28 AM
CharleyL's Avatar
First Name: Charley
As an electrician (many years ago) I needed one of those on two different occasions. In both cases, I was trying to get wires from the wall into the ceiling and there was a double joist sitting right on top of the wall. For both I ended up chopping out a lot of wood and sheet rock that wouldn't have been necessary if I had one of these, but there's no point in me making one now. It's been almost 50 years since the last time I needed it. I now leave that kind of work to younger guys. Izzy is quite inventive and interesting to watch though.
Charley
CharleyL is offline
post #8 of 12 (permalink) Old 09-06-2016, 07:30 AM
didn't Milwaukee make a bit that did something like that...
post #9 of 12 (permalink) Old 09-06-2016, 07:32 AM
curved hole wiring bits - ICS Cutting Tools
post #10 of 12 (permalink) Old 09-06-2016, 07:56 AM
Bushwhacker's Avatar
First Name: David
https://www.youtube.com/watch?v=LRvF...em-uploademail
I can see one very good use for it. Back when I rewired this old house we live in. It would have been very handy when I got to a corner lead and had to drill into it from both d\sides to get a wire through it.
RainMan 2.0 likes this.
When the enemy is in range, so are you.
Bushwhacker is offline
How to make hole in base of router larger? kglade Guide Bushings and Templates 15 05-31-2016 01:16 AM
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 17 04-24-2014 09:02 PM
Court Rejects Moratorium on Drilling in the Gulf Bebca051 New Member Introductions 3 08-13-2010 12:29 AM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 08:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 05:29 PM
