Cutting board problems, for change - Router Forums
 1Likes
post #1 of 18 (permalink) Old 09-08-2016, 02:57 PM Thread Starter
First Name: Barry
Default Cutting board problems, for change
I haven't been in the shop for over a month due to a basement clean up task that helped to aggravate a partial tear in my rotator cuff. Got a shot of cortisone yesterday so I'm anticipating an improvement. Hoping to get back into the shop, today I checked 5 completed cutting boards that have been on the shelf for over a month. All of them have been mineral oiled and then a final coat of mineral oil and bees wax. Four of them are end grain and one is edge grain. One of the end grain and the edge grain are fine. However, the other three end grain boards have moved. One has a slight twist and the other two have, what can best be described, as a slight cup. One of them I can make swivel like a lazy susan!!
So, my problem. How to fix them. Some of you may call me crazy, and you probably would be right, but I flattened the end grain boards using my thickness planner. I added sacrificial strips to all edges to level the board and to eliminate tear out and took off about 1/64" or less on each pass. Never had a problem. Anyway, i probably wouldn't have to take much off to re-flatten them but can I do that with the planner since the wood is now oiled. I can remove what little wax is on there with a card scraper. Sanding is out of the question and I don't have router skis.
Any and all suggestions are appreciated since I really don't want to mess up the boards although I do have one which I don't love that will be my test board.
Barry747 is offline
post #2 of 18 (permalink) Old 09-08-2016, 08:12 PM
You could plane them again but I would clean the knives right away. A router sled doesn't take long to throw together either.
post #3 of 18 (permalink) Old 09-09-2016, 08:15 AM
Bushwhacker's Avatar
First Name: David
Sounds to me like you have it covered.
rrrun likes this.
When the enemy is in range, so are you.
Bushwhacker is offline
post #4 of 18 (permalink) Old 09-09-2016, 11:28 AM
rwl7532's Avatar
First Name: Ralph
Card scraper as stated and rub the surface with acetone with a few different shop rags or paper towels.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #5 of 18 (permalink) Old 09-09-2016, 12:06 PM
That is not a terribly uncommon occurrence. I just flip it over and it will straighten out.
billyjim is offline
post #6 of 18 (permalink) Old 09-10-2016, 10:09 AM Thread Starter
First Name: Barry
Bill, Thanks for the suggestion. Sometime the simplest answer is overlooked. i flipped the boards over with the most distorted on the bottom of the stack, cup side up, and piled the rest on top. I'll give it a week or two and see if it makes any difference. If not, I can always go back plan A. I'll post the results in a couple of weeks.
Thanks guys.
Barry747 is offline
post #7 of 18 (permalink) Old 09-10-2016, 10:21 AM
let some air and atmosphere get to them...
unstack them..
Stick486 is offline
post #8 of 18 (permalink) Old 09-10-2016, 11:10 PM
unstack them..
Or lay some strips between them an then stack weight on so that it gets pressure and air.
post #9 of 18 (permalink) Old 09-11-2016, 07:46 AM
yup abd finish the stack w/ a CMU...
Stick486 is offline
post #10 of 18 (permalink) Old 09-11-2016, 09:11 AM Thread Starter
First Name: Barry
Thanks guys, I'll sticker them into a small air drying stack with a weight on top. Stick - forgive my ignorance but CMU?
Barry747 is offline
cutting board blood groove joegillespie New Member Introductions 11 01-10-2015 12:29 PM
Cutting Board Finger Holds rrrun Router Bits - Types and Usage 7 12-10-2014 08:55 AM
Quilted Cutting Board Pop_pop1 Show N' Tell 13 11-11-2011 11:03 AM
Cutting a slot in the middle of a board Zurt Table-mounted Routing 11 01-11-2011 09:46 AM
Walnut/Maple Cutting Board TRN_Diesel Show N' Tell 26 12-21-2009 10:57 AM
