Problem with Trimming Edge Banding - Router Forums
 17Likes
post #1 of 20 (permalink) Old 09-13-2016, 08:51 AM Thread Starter
chuckgray's Avatar
First Name: Chuck
Default Problem with Trimming Edge Banding
I recently attempted edge banding for the first time and have utterly failed. I'm applying 7/8" birch banding to 3/4" birch plywood. I didn't have any problems getting the banding to stick using a hot iron. My problem arose when I tried to trim it.
I bought one of those hand-held double-sided trimmers and it seems to want to trim into the portion of the banding that isn't supposed to be trimmed into. I read the reviews on the device when I bought it and there were suggestions from other buyers to make sure that you trim with the grain and to do only one side at a time by separating the trimmer and only using one half of it. I've used both of these suggestions and I'm still having problems.
Anyhow, I need to try something different and I'd like to hear how the rest of you trim the excess banding. I've considered using my router with an edge trimming bit, but am a little apprehensive about not have a stable enough platform for the base of the router to ride on. I can totally visualize the router tilting and digging into the workpiece causing additional frustration and anxiety. And I've just reordered another roll of the banding and I'd prefer not to have to reorder a third one (at least, not for this same project).
Thanks in advance for any help you can provide.
chuckgray is offline
post #2 of 20 (permalink) Old 09-13-2016, 09:24 AM
schnewj's Avatar
I don't have good luck with these double edge trimmers. It is one of those five minute tools that allows you to finish up five hours later.
I generally, use a razor knife or an EXACTO Knife to trim the edges. Start at the end and hold the blade as flat as you can and run it along the edge of the piece. Angle the tip away from the direction of travel and keep the pressure towards the banding. The banding is thin enough that the knife blade should be more than adequate. You should get a very fine curl of material being sliced off. You may have to make a couple of passes to ensure it is flat to the surface.
Then, use either use a block plane (set really shallow) or a piece of fine grit sandpaper on a backer (piece of wood) and break the edge a little. Again, pressure towards the banding. Never cut towards the banding as it may break it loose from the edge. The sandpaper will, also, allow you to get into inside corners.
Hope this helps.
BrianS, MEBCWD, billyjim and 3 others like this.
schnewj is offline
post #3 of 20 (permalink) Old 09-13-2016, 09:39 AM
Nickp's Avatar
First Name: Nick
+1 on Bill's approach...my weapon of choice also...
I've been known to use a small block of wood to keep the blade flat on the other side of the banding...keeps my fingies from turning red...
Nick
Nickp is online now
post #4 of 20 (permalink) Old 09-13-2016, 10:52 AM
After years of trimming laminate self-edge, I use a file to trim the iron-on wood tape. If you start at one end and get the overhang down to the plywood surface, feeding the file sideways along the part with shear the wood tape off using the teeth on the edge of the file. Try that - with a little practice, you'll be surprised how well it works and how quickly it goes too.
MEBCWD likes this.
tomp913 is offline
post #5 of 20 (permalink) Old 09-13-2016, 11:08 AM
you are using the trimmer against the grain.. cut the other di8rection...
and put sharp razors in it...
use your router w/ a trim bit...
here's extreme...
the shortcut would be to put blocks of scrap between the panels and clamp the stack together...
I like this way more gooder.. (PDF)...
and while yur at it.. use this style blade...
post #6 of 20 (permalink) Old 09-13-2016, 12:22 PM
I would size the end grain with diluted glue before you iron on, about a 50/50 mix. Otherwise you risk the tape peeling off later. (Same for particle board.) Add more until the end grain starts to look a little shiny if necessary. I would use a similar method to Bill but probably use a chisel making a shearing cut pressing into the banding. I would try using the widest practical chisel so that I could hold the point down on the flat behind the banding for stability. My chisels are close to being as sharp as Bill's knife.
billyjim, Stick486 and schnewj like this.
post #7 of 20 (permalink) Old 09-13-2016, 12:37 PM Thread Starter
chuckgray's Avatar
First Name: Chuck
I appreciate all the comments. I think I'll try Bill's suggestion using an exacto knife since it looks like the easiest way for me.
MT Stringer likes this.
post #8 of 20 (permalink) Old 09-13-2016, 12:42 PM Thread Starter
chuckgray's Avatar
First Name: Chuck
I agree Stick, but I'm having trouble reading the grain on the banding. And it sometimes changes direction along the length and I overlook that too. Perhaps the exacto option will work for me...
post #9 of 20 (permalink) Old 09-13-2016, 01:50 PM
schnewj's Avatar
Ditto, on the chisels.
here's extreme...
and while yur at it.. use this style blade....
Stick, he's referring to 7/8" wide iron on edging not applying a hardwood edge. A router is overkill for this.
I, also, use a chisel. The trick is, that, whatever you use keep it flat to the surface and make sure that it is SHARP.
Cherryville Chuck likes this.
schnewj is offline
post #10 of 20 (permalink) Old 09-13-2016, 03:14 PM
[QUOTE=schnewj;1323434]Ditto, on the chisels.
I know he is...
a trim router is not overkill..
fast/easy and you can climb cut w/o worries..
TomE and billyjim like this.
choosing an edge guide to do inlaid banding tomcoleman General Routing 22 05-20-2016 09:53 AM
edge banding spidennis Router Bits - Types and Usage 10 05-07-2013 10:24 AM
unique problem flush trimming jwoody New Member Introductions 3 01-01-2013 06:16 PM
finger joint bit for edge to edge atmartin23 Router Bits - Types and Usage 20 09-04-2009 02:51 PM
edge trimming bit selection RonH Router Bits - Types and Usage 1 04-08-2009 01:49 PM
