Polk ultimate portable workbench - Router Forums
 22Likes
post #1 of 22 (permalink) Old 09-29-2016, 09:36 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Polk ultimate portable workbench
Anyone built it ? I've tried several things but I not happy. Want it for my track saw
Here is a link
clarkkent88 and pinehunter like this.
roofner is offline
post #2 of 22 (permalink) Old 09-30-2016, 01:16 AM
JOAT's Avatar
First Name: Theo
Doesn't look like anything I couldn't do with a solid core door and a couple of sawhorses. I prefer designing my own stuff, that way I get just what I want/need, and not what someone else thinks I need.
TWheels, Shop guy, Nickp and 1 others like this.
JOAT is offline
post #3 of 22 (permalink) Old 09-30-2016, 06:06 AM Thread Starter
roofner's Avatar
First Name: Gary
I like the tool storage idea not fumbling for tools. Convenient hold downs.
OPG3 likes this.
roofner is offline
post #4 of 22 (permalink) Old 09-30-2016, 09:22 AM
I saw the same thing on fastcaps website the legs were a little different but the top was the same
hammerheadmike is offline
post #5 of 22 (permalink) Old 09-30-2016, 09:32 AM
CharleyL's Avatar
First Name: Charley
The Paulk work bench is a pretty well thought out design, for a portable work bench, but for just breaking down sheets or using a track saw, I prefer a cutting table. It's just a frame of a table with banquet table legs. My table perimeter is made from 1 X 4 pine with 2 X 4 cross pieces laid flat and flush with the top edge of the 1 X 4 frame. There are five of these cross pieces, 2 near each end where needed to attach the table legs, and one in the middle for added strength. There is no metal in my table. It's all joined together with glue and biscuits. The only metal in the wood are the short screws that attach the table legs, which are an inch below the table surface, and the two screws that attach the small pieces of plywood to one long side of the table, which are more than 1 1/2" below the top surface of ther table. The table size does not need to be as large as a sheet of plywood. Mine is about 30" wide and 70" long, but it can be any size that you want it to be. Just make it at least about 2/3 the size of sheet stock so the larger, less than full size off cut pieces can remain safely on the table without needing to balance them. I just slide the sheet stock around so that the cut line is roughly centered over the table, to keep the off cuts from falling when the cut is complete. For very narrow rip cuts of the full length of the sheet I usually just do these off the edge of the table, since they are light and I can support them with one hand while operating the saw with the other. The banquet table legs are available from Harbor Freight, Northern, and other sources for about $25 per pair
To use the table, I just set it up on a flat surface (usually my driveway) and lay the piece(s) to be cut on the top of it. Since I don't have a true track saw I use an aluminum straight edge clamp and my circular saw with a zero clearance base plate on it. I set the saw to cut about 1/4" deeper than the thickness of the material that I will be cutting and then just make the cuts. The beauty of using a cutting table like this is that 1. you don't have to worry about off-cut pieces falling when the cut is complete. 2. The work is at a comfortable level 3. The kerfs made in the table pieces do not affect the table's strength. If I ever make so many kerfs in the table frame that I want to replace it, I just make another and move the legs to it. When I'm not using my cutting table, the legs fold easily and flush with the bottom of the 1 X 4 frame. I then just lean it up against my plywood stock in my shop.
The pictures attached are of my first cutting table. After 4 heart heart attacks and surgery for each, plus two knee replacements I have considerable difficulty lifting full sheets of 3/4" plywood and my heavy cutting table, so wised up and remade the table lighter by changing the outer frame from 2 X 4 to 1 X 4 and it reduced the table weight by about 18 pounds. To move full sized sheet stock around I have a wheel assembly that I place at one end under the bottom edge of the stock, and then I lift and carry the other end of the sheet to wherever I need it.
I also added two pieces of plywood on one long side of the table frame, attached off center with just one screw. I can turn these so they are below the top surface of the table, or turn them so they are above the table surface. Turning them so they are up above the surface lets me tip the table on it's side with these down against the driveway, then lean a full sheet of plywood or other sheet stock against the table surface with the bottom edge of this stock sitting on these two pieces of plywood. I can then bend down and tip both the table and the sheet stock up so the table is again on it's legs, but with the sheet stock then laying flat on the top of the table. (I added this feature to the original table and it worked so well that it's now also on my newer, lighter version of the table.
If I ever make so many kerf cuts in the top of this table that I become unhappy with it, or worry that it's not as strong as it should be, I'll just make a new wood frame top and move the legs from the old one to the new one, but I doubt that I'll live long enough to ever need to.
Again, the attached photos are of my heavy first table. My second version uses 1 X 4 for the outer perimeter frame and 2 X 4 material for the cross pieces and it's plenty strong enough.
At a large family picnic where we ran out of table space, I set my cutting table up with a full sheet of 3/4 cabinet birch plywood on it, covered it with a table cloth, and set up folding chairs around it. Some of the guests were wondering where I had found such a large perfect table for the picnic, until I told them what was under the table cloth.
If you should need a work bench area for tool storage and you don't need this as a cutting table, a piece of plywood to cover it, and you can use it as a light duty work bench or tools and supplies table.
If I'm helping someone do some woodworking away from my shop I always take my cutting table with me. I prefer it much more than saw horses for general use woodworking.
One photo shows the bottom of my saw with my clear lexan "zero Clearance insert" attached to it. If you make one of these, you only need the "zero clearance function where the blade teeth rise up out of the cut. Notice that the opening widens out behind this so that the blade guard can still function. A single narrow slot the full length of the blade would prevent the blade guard from operating, and the saw would be very dangerous to use. If you make a zero clearance insert, make certain that the blade guard can still operate after you attach it to your saw.
Charley
Central North Carolina
CharleyL is offline
post #6 of 22 (permalink) Old 09-30-2016, 09:45 AM
Nickp's Avatar
First Name: Nick
Nice one, Charley...I particularly like the "Sheet-goods Lifting Assistant Mechanism" (SLAM) you built into it...very creative...
Nick
Nickp is online now
post #7 of 22 (permalink) Old 09-30-2016, 10:17 AM
CharleyL's Avatar
First Name: Charley
Thanks Nick. My shop is too small to break down sheet stock inside it with my Unisaw, so this table gets used frequently. Since I don't have a track saw, I usually cut my pieces slightly larger, and then take them into the shop and cut them to their final size. I may someday invest in a track saw, but my method using my cutting table has done very well for me for about 10 years now. I don't even own saw horses any more.
Charley
CharleyL is offline
post #8 of 22 (permalink) Old 09-30-2016, 11:11 AM Thread Starter
roofner's Avatar
First Name: Gary
Actually I am not going to build his design. I got a much simpler but similar concept. I will post picture of the work I have done . I have something I use now that will replace his support system.
roofner is offline
post #9 of 22 (permalink) Old 09-30-2016, 11:58 AM
MT Stringer's Avatar
Fastcap is marketing a kit...24x48 or thereabouts. Perfect for beginners or someone that just wants to do the assembly and no cutting.
I have one of his plans purchased several years ago. Used it as reference when i built my miter saw station.
MT Stringer is offline
post #10 of 22 (permalink) Old 09-30-2016, 12:27 PM
TwoSkies57's Avatar
IIRC there are several videos on youtube regarding this particular design. I like it. I'd be tempted to do something like this for a full time bench in the shop..
Skipper the Penguin
TwoSkies57 is offline
Ultimate Workbench MT Stringer Project Plans and How To 13 08-17-2016 07:17 PM
New Fangled Workbench - Portable FreeTime Tools and Woodworking 8 04-15-2013 05:11 PM
Portable router table kodena Table-mounted Routing 6 10-25-2012 09:51 AM
My first Workbench Burke Show N' Tell 11 10-15-2011 10:25 PM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 02:54 PM
