Squaring stock?! - Router Forums
 5Likes
post #1 of 12 (permalink) Old 10-08-2016, 04:06 PM Thread Starter
First Name: Lee
Default Squaring stock?!
Hi everyone,
I am struggling to square stock for projects I have. When I run wood through my table saw it has tool marks that heavy sanding would remove. Is this a table saw set up issue? Or do I have to invest in a jointer?
How do you guys square your stock? Are there any good guides for squaring with limited tools!!
Eazygeezer is offline
post #2 of 12 (permalink) Old 10-08-2016, 04:30 PM
table saw set up...
are you starting w/ square and then going square after the cut???
How to Set Up Your Table Saw for Perfect Cuts | Woodworking
Table Saw Basics - Alignment - NewWoodworker.com LLC
post #3 of 12 (permalink) Old 10-08-2016, 04:45 PM
Honored Member
First Name: pat
Some tips.
Probably not a saw set up issue.
Wood changes shape as its cut. It can pinch the blade or separate.
It has a mind of its own.
If you're after perfect milling it has to be done twice!
Once to rough size, depending on the stress relief.
And again to final dimension after gestating in the shop, equilibrating.
Quillman is offline
post #4 of 12 (permalink) Old 10-08-2016, 06:44 PM
MT Stringer's Avatar
One of my blades is a glue line rip blade with 80 teeth or something like that. It makes perfect rips.
But to square up rough stock, especially that which is bowed, I use a table saw ripping sled. I clamp the board to it and pass the wood over the blade. The sled rides against the fence. That makes a straight side of the work piece. You can then turn it around and rip the other side as needed to get the desired width.
I guess the bottom line is a jointer is needed to obtain one flat side and one square edge 90 deg to the flat side. Then run the work piece through the planer to get the desired thickness. The final step is to rip the second edge parallel to the first.
There are a lot of videos on You Tube that should provide some insight.
Hope this helps.
Shop guy likes this.
MT Stringer is offline
post #5 of 12 (permalink) Old 10-08-2016, 07:12 PM
your saw marks can happen w/ economy blades or the incorrect blade...
post #6 of 12 (permalink) Old 10-08-2016, 07:13 PM
Lee; if you're talking about smaller pieces, hand planing is certainly a very effective and satisfying method.
Low stress and low noise; you can put on some fav CDs and just get in the groove!
A couple of very knowledgeable guys at our wood guild introduced me/us to the LV line of bevel up planes...I'd never handled one before and I'm now stoked!
I absolutely love them.
Lee Valley Tools - Online Catalog
pgs 138-139
DaninVan is offline
post #7 of 12 (permalink) Old 10-08-2016, 08:08 PM
Lee I would go through the checks in the link Stick gave about alignment. The blade needs to be parallel to the mitre grooves first and then the fence also needs to be parallel with them. You can have both parallel to each other and not the table but that's not a good situation even though it will rip okay. You can tell if something is out if the back edge of the saw blade is making contact with either side of the cut. Adjust the fence accordingly. You can also tell by the direction of the score marks if the back of the blade is also cutting.
A good blade is also important. A poorly ground blade may track to one side and cause a wobble. Sometimes blade stiffeners can really help with thin rim or poor blades.
Last, it may be like Pat Warner said. Some wood can have lots of tension in it. Some species are worse than others for this. I've seen some bad tension in red oak in particular. I've had cuts close together so tight it stopped the blade on a 1 hp saw.
RainMan 2.0 likes this.
post #8 of 12 (permalink) Old 10-08-2016, 11:15 PM
First Name: lee
I think a jointer is the easy way to square stock. Run the board across the jointer which will give you a flat side to run against the table saw fence.
You do need your table saw aligned to cut properly.
coxhaus is offline
post #9 of 12 (permalink) Old 10-09-2016, 03:37 AM
vindaloo's Avatar
First Name: Angie
How many teeth does your blade have? 24 for ripping, 40 is general purpose, 60 and above gives great cross cuts and can also be used to give a smoother rip cut.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #10 of 12 (permalink) Old 10-09-2016, 04:58 AM
As the answers suggest, this can be a complex issue. If you don't yet have a Wixey digital angle gauge to check for that 90 to the table, get one for about $30 on Amazon. You can use a combination square to check blade alignment with the miter slot by marking one tooth and checking the distance from slot to that tooth twice, once with that tooth at the front of the opening, once at the back. Different saws have different ways of adjusting this. If the blade is not parallel to the slot, you will likely have to loosen the table and shift if very carefully one way or another to align it. But then the blade may still be a problem.
I have switched to full kerf blades because the thin kerf blades may deflect from the tension in the wood, and who knows if a cheaper blade is really flat. If it isn't you'll get saw marks or burning. On good quality thin kerf blades, I have a 4 inch stiffener installed, which helps some. I learned a lot about blade deflection while
struggling to get a perfect 45 miter corner for frames, and finally gave up on thin kerf blades for exact cuts.
I popped for a Woodpecker dial gauge to check with more precision on blade alignment, but also use it to set the fence ever so slighly wider from the blade toward the back of the table. Mine is set for 4/1000ths out rather than exactly parallel. While checking this I discovered that my fence, although very good is not really perfectly straight, so setting the back end out slightly eliminates the fence pushing the leading edge of the workpiece to the side.
I do have a table saw jig I can clamp a board to to get a quick straight edge, but it does nothing to correct twists, bowing or other directionally stressed wood, particularly the stuff you generally find at HD. I've become extremely fussy about what I buy there and often find one piece out of 50 that's close enought to straight, and that has a grain structure that is straight enough not to warp on the way home.
Things got much better when I finally got a good jointer. Wish I'd gotten one with a wider blade, but what a difference it makes. One problem even with that is if you buy wood that's already dimensioned to your final size (as it is with big box wood) there is no way you can really plane it flat and have the same dimension. It will always wind up thinner. So you need to buy stock that is not only straight as you can find, with good grain structure but that is at least a quarter inch thicker than what you finally want. If its a truly critical build, the two step planing is necessary, with a day or so of climitizing in the shop before you do the second and final planing. And then you need to use that freshly planed wood within a day or so. This is a very fussy approach that is used for furniture and other very close tolerance builds.
Hand planing takes a little practice and learning to sharpen "wicked sharp." But planing itself is a very satisfying way to flatten and dimension wood. On top of that, it leaves a fantastic surface that is far more glassy that you can ever get with sanding, even with the finest grits. I now have collected 5 different planes, Wood River V3 planes do it for me, although I do have a Veritas router plane tucked away for cleaning up grooves and such. Most of the time I use a #4 jack plane, but I also have a #6 to flatten with. The extra length makes it better for flattening. But it's a lot of work to do a large number of pieces this way. Planes get in your blood after awhile, and sharpening and setting them properly takes practice. Worth considering is that a decent set of planes will cost nearly as much as a jointer and planer, and the two tools go together. Notice that nearly all skilled woodworkers have a set of planes handy.
There ARE lots of videos on YouTube on all of these methods, but I also found a lot of information in used woodworking books about specific tools on Amazon. The methods and techniques have been around forever so older books are still valie. Do remember that many of the finest antiques were built entirely with hand tools that were not near as good as we can get today.
Once again I've penned a novella, but I hope some of this is useful. How detailed YOU need to get depends on the project, your standards and pocketbook.
firstmuller likes this.
Center finder for drilling round stock Gaffboat Tool Reviews 21 10-02-2016 08:05 AM
Zero clearance inserts. (table saw) jw2170 Shop Safety 33 11-12-2012 05:04 PM
Need Jig for Dovetailing ½” stock + Rockler woes + Katie? JavaGeek Jigs and Fixtures 16 02-17-2011 02:46 PM
1/2" Stock for Raised Panel rdlorenzo Router Bits - Types and Usage 5 11-19-2010 10:00 AM
An alternative way to hold stock harrysin Guide Bushings and Templates 5 02-18-2007 03:47 PM
