What Wood For Jig Collar - Router Forums
 5Likes
  • 4 Post By Stick486
  • 1 Post By Herb Stoops
post #1 of 4 (permalink) Old 10-08-2016, 04:04 PM Thread Starter
Contributor of the Month
Default What Wood For Jig Collar
I want to make a flat collar out of wood that will be tightened via a threaded rod with a knob or nut. The collar will be 3/4" thick. Hole through the center of the collar board, thin saw kerf running from the outer edge to the center hole. The rod and knob will tighten the hole around the tool. Think plunge type base for a trim router. The question is what would be the best wood for this? It will have to have a little spring to it so it won't split when the saw kerf is drawn closed.
JIMMIEM is offline
post #2 of 4 (permalink) Old 10-08-2016, 05:15 PM
bent white oak laid up long grain..
buy a wooden embroidery hoop.. they come in a bazillion sizes,,
Stick486 is offline
post #3 of 4 (permalink) Old 10-08-2016, 07:09 PM
Gene Howe's Avatar
First Name: Gene
White oak, as Stick suggested. Make your cut across the grain.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 4 (permalink) Old 10-08-2016, 11:23 PM
I make mine out of BB plywood or Maple. I have one on the drill press w/4" hole to clamp on the column and a 4" hole in a yoke to hold my DC hose. An other one out of 1 1/2" material,maple to hold a small grinder in my DP vise to do spindle grinding.
jj777746 likes this.
Herb Stoops is online now
Wood Species dattashri Wood Species 7 07-26-2012 10:23 AM
Exterior wood Treatment dattashri The Finishing Touch 3 05-14-2012 11:37 AM
Attaching Patterns To Wood Vector01 Wood Scrolling 4 10-18-2011 01:50 AM
Best Places to buy wood? big wes New Member Introductions 12 01-26-2010 04:34 PM
