Miter Saw or Table Saw - Router Forums
 45Likes
post #1 of 43 (permalink) Old 10-12-2016, 06:57 PM Thread Starter
bdbailey's Avatar
First Name: Benjamin
Default Miter Saw or Table Saw
Hi! I'm preparing my family's garage to have basic woodworking tools. Both the miter saw and table saw seem useful, but we should be careful with our budget. Which saw would be a better "first"? We have an old circular saw, jigsaw, and... that's it. Some basic hand-saws and now a coping saw. I know a miter saw can cut great, accurate angles, which would be wonderful for every project. But if we want to run longer boards, I think a table saw would be the right tool. For what we do (smaller projects/home improvement) I think the miter saw would be great. Since we've never owned either type of saw, however, I can't say. Down the road, can we get a higher-quality circular saw and mount it to a table? Also, is it fine to buy these power tools used?
Apologies, usually my posts are well-organized, but this one turned into a long mess. Any advice is very welcome!
bdbailey is offline
post #2 of 43 (permalink) Old 10-12-2016, 07:35 PM
RainMan 2.0's Avatar
IMO there both the first things you buy , but if I could only have one it would definitely be a table saw. Table saws usually come with miter gauges , so you can do angled cuts too .
A little more versatile than the wmiter saw .
My concern is the fence on cheaper models of table saws will give you headaches . My first saw was a Delta contractors saw ,but I ordered it with the Beisemeyer fence which is a tank and won't have any deflection issues
OPG3 and Danman1957 like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 43 (permalink) Old 10-12-2016, 08:26 PM
First Name: Jerry
My very first table saw was a Craftsmn $167 piece of junk, I couldn't give it away fast enough, so try to buy the best that you can afford and if you can't afford a fairly decent tool, save your money until you can. If you buy cheap, in the long run it will be the most expensive. I think that trying to put a circular will give you to many head aches, but that's just my opinion.
If you are careful and have the time, you can do a lot with your hand saws to start with untul you decide on what you really want and can afford. Wishing you the best,
Jerry
RainMan 2.0 likes this.
Jerry Bowen is offline
post #4 of 43 (permalink) Old 10-12-2016, 08:34 PM
JOAT's Avatar
First Name: Theo
Indeed. The solution is to hang the fence on the wall, and make at least one saw sled. Worked like a charm for my Harbor Freight saw, the one I still have, and use.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #5 of 43 (permalink) Old 10-12-2016, 08:44 PM
My table saw is the most important tool in my shop and I didn't scrimp on it, it's a 3 hp Unisaw. Spend enough to get a good one, it doesn't have to be a unisaw, but make sure it has a good fence as mentioned. You can do very good miters on a table saw. I have 2 sleds that come in very handy. One is for 90 degree square crosscuts and the other is square 45 degree cuts. A good after market miter gauge will give you very accurate angled cuts (Osborn, Incra, Kreg, and JDS Accumiter all make good miter gauges). Between the sleds and the after market miter gauges you can do anything a chop saw can do and with wider material. The trade off is that you are constantly adjusting the table saw which is slower than adjusting chop saws.
OPG3, Danman1957 and RainMan 2.0 like this.
post #6 of 43 (permalink) Old 10-12-2016, 09:11 PM
If you're talking about construction, Ben, as opposed to cabinetry or fine woodworking, I'm going to be the odd man out here.
No question in my mind that for doing reno's a sliding compound mitre saw (as opposed to a straight chop saw) is far more practical. You just can't handle long lengths on a table saw...who has that kind of real estate around their tablesaw?
There's not much you can't do with a good quality circ. saw, good blades, and some simple to make jigs, for the ripping and panel cutting that are all part of the process.
Don't skimp on the blades! Having said that, I picked up a Cdn. Tire house brand thin kerf blade for my SiL's circ. saw and I was blown away by how easily it ripped down 1" thick PT decking material; as fast as I could slide the saw it made the cuts effortlessly!
* Oh! And you can take the SCMS and circ, saw right to where you're actually working. Can't do that with a cabinet saw...although the smaller construction type portable tablesaws will certainly be that adaptable.
TWheels, Danman1957 and Nickp like this.
DaninVan is offline
post #7 of 43 (permalink) Old 10-12-2016, 09:13 PM
First Name: Richard
I agree with Charles. In my opinion the table saw is the king of the shop. I use sleds and an Incra 1000SE which is more accurate than a lot of miter saws. My suggestion would be to go for the table saw then a good router. I don't use my miter saw that much any more but I'm always using the saw and router. Search YouTube for videos and ideas.
Shop guy is offline
post #8 of 43 (permalink) Old 10-12-2016, 09:25 PM
Marco's Avatar
I agree! add a Kreg Rip Cut Guide for the circular saw and you are ready to go. https://www.amazon.com/Kreg-KMA2675-...+rip+cut+guide
Galatians 5:13
Marco is online now
post #9 of 43 (permalink) Old 10-12-2016, 09:48 PM
First Name: lee
TABLE SAW. It is the heart of a woodworkers shop. Find an old Delta Contractor saw. Add a T2 or T3 fence when you have more money.
coxhaus is offline
post #10 of 43 (permalink) Old 10-12-2016, 09:50 PM
Ben asked: "Down the road, can we get a higher-quality circular saw and mount it to a table?"
What are you using now? Just because it's old doesn't mean that it's inadequate for the purpose for which it was designed. It might benefit from a tune up, and being adjusted for accuracy, but if it hasn't been dropped or otherwise abused it's probably still got lots of life left in it.
One blade doesn't do everything. You need a 24 tooth blade for ripping and a 40 tooth for fine cuts.
As for mounting it upside down in a table, don't bother. There's tons of past threads here that explain crosscut jigs, not to mention You tube vids explaining the concept. For ripping boards, use the rip fence that saws are designed to accept. There's 3rd party models available if you can't locate the one for your saw.
Plywood Crosscut Guide - Popular Woodworking Magazine
https://s-media-cache-ak0.pinimg.com...3d756e3101.jpg
http://www.pennstateind.com/graphics/pps-b.jpg
Danman1957 likes this.
DaninVan is offline
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 07:41 PM
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 11:30 AM
miter saw vs table saw w/ miter gauge Everend Tools and Woodworking 23 04-06-2013 10:07 PM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Miter T-track attachment to the router table Chase Jigs and Fixtures 10 07-11-2011 11:23 AM
