hole saw vs forstner bit - Router Forums
post #1 of 7 (permalink) Old 03-19-2005, 10:55 PM Thread Starter
Default hole saw vs forstner bit
can anyone tell me the difference in a hole saw and a forstner bit? when would you use one bit over the other?
i have a project that requires a 4" hole to be drilled and a 1/2" hole drilled but only 1/4" deep. hat is the best item to use to do both these knowing that i do not have a drill press????
reds_21
reds_21 is offline
post #2 of 7 (permalink) Old 03-19-2005, 11:27 PM
reible's Avatar
You can not use a Forstner bit of 4" dia without a drill press..... well maybe if it were mounted on a post hole digger....
A hole saw is going to interesting at 4" dia...... have you priced one yet?
Any reason you don't want to use the router? I can't picture what your making but if you need a 4" dia hole 1/4" deep I myself would use a router and make a simple jig/template and route it out.
If you need details let us know.
Ed
reible is offline
post #3 of 7 (permalink) Old 03-20-2005, 12:33 AM
Shawn, I have a 4" hole saw. It requires a beefy 1/2" drill motor to turn it, and you need a second handle on the drill to control it. The 1/2" hole would be easiest with a Forstner bit. Simply mark a line on the bit 1/4" from the end of the teeth and stop drilling when you reach it. If you had a plunge router you could use a 1/2" plunge bit and simply plunge in the 1/4" depth.
post #4 of 7 (permalink) Old 03-20-2005, 09:49 AM Thread Starter
reible
maybe i was unclear, sorry. the 4" hole will actually be cut completely out. as for the 1/2" hole, that needs to be 1/4" deep. so if i don't have a plunge router what is the easiest way to cut these holes so they are true? Mike mentioned the forstner bit for the 1/2" hole (Thank You Mike) but any suggestions on the 4"??
reds_21 is offline
post #5 of 7 (permalink) Old 03-20-2005, 10:08 AM
First Name: Richard
Hi Shawn:
I would go with a router for the 4" hole, without a drill press you would never be able to hold onto a drill with that size saw. Plumbers use 4" hole saws but they also use a large slow speed drill, usually the Milwaukee right angle drill. I would make a template and use the router for the big hole and a fostner bit for the 1/2' hole..
Good luck Woodnut65
Woodnut65 is offline
post #6 of 7 (permalink) Old 03-20-2005, 10:30 AM
Shawn, when you go to make your 4" hole you can drill a starter hole and rough cut it with your saber saw. Use the template/guide bushing/straight bit to finish it to size. You can buy the guide bushings for your router cheap enough at Sears.
post #7 of 7 (permalink) Old 03-20-2005, 10:48 AM
First Name: jerry
what is the material you are attempting to cut a 4" hole through ?.
regards
jerry
jerrymayfield is offline
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 17 04-24-2014 09:02 PM
Room divider finished jigger Jiggers Gallery 17 09-27-2011 12:05 AM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 07:49 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 08:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 05:29 PM
