Air Compressor done? - Router Forums
 22Likes
post #1 of 42 (permalink) Old 10-14-2016, 04:15 PM Thread Starter
Default Air Compressor done?
My little 8 gal BCP air compressor that I keep in the basement wouldn't go when plugged in. Nothing. Question is ...... what could it be and is it worth fixing. It is 15 years old or better. I'm thinking control valve. Is it worth fixing or just buying another small one. All I use it for is blowing dust off the CNC bed and benches, and a little finish nailing. A new control valve itself is $30+.
HJ
honesttjohn is online now
post #2 of 42 (permalink) Old 10-14-2016, 04:49 PM
Nickp's Avatar
First Name: Nick
I'm more of a fixer type...I'd rather spend $30 than $100 on a small new one...IF...the rest is in good shape...no rust, motor good, connections, control valves, etc...
You could also use the exhaust port of a shop vac (if it has one) to do what you need (in a pinch)...
JFPNCM and DaninVan like this.
Nick
Nickp is online now
post #3 of 42 (permalink) Old 10-14-2016, 04:56 PM Thread Starter
Touble is, I don't know if it's the control valve. I'm just guessing. The rest of it is in good shape. Just been sitting in the basement or garage. Hardly ever even moved.
HJ
post #4 of 42 (permalink) Old 10-14-2016, 05:40 PM
John, put it up on the bench so you don't have to bend over; step #1.
Take the switch box completely apart and give it a really good cleaning...check the contacts for crud, and loose connections. Disconnect the cord and check it for continuity.
Once you've eliminated everything electrical, then start on the control mechanisms. Been down this road with my old Campbell Hausfield.
I did eventually replace all the air pressure activated parts but that was more of a midlife rebuild; they didn't owe me anything. My original issues were strictly electrical contact related.
MEBCWD likes this.
DaninVan is offline
post #5 of 42 (permalink) Old 10-14-2016, 05:53 PM
hawkeye10's Avatar
First Name: Don
John it being so old do you think it's worth fixing? This is one of those things that could go either way.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 42 (permalink) Old 10-14-2016, 07:04 PM
First Name: Ken
After seeing pictures on here of an exploded air tank, I'd consider the possibility of rust in the tank in my fix/replace equation.
RainMan 2.0 likes this.
kklowell is offline
post #7 of 42 (permalink) Old 10-14-2016, 07:07 PM
RainMan 2.0's Avatar
You beat me to it
Ok ,I never insulate
RainMan 2.0 is offline
post #8 of 42 (permalink) Old 10-14-2016, 07:13 PM
clean the contacts on the pressure switch...
check the start capacitor... if it has one...
test out the motor...
File Type: pdf Electric Motor Troubleshooting (Polyphase).pdf (850.1 KB, 44 views)
MEBCWD likes this.
post #9 of 42 (permalink) Old 10-14-2016, 07:31 PM
Cheap compressors are oil-less. That means after about 500 hours, most give up the ghost. Personally, I'd just get another. Some things are repairable, some might be but aren't worth repiaring, and some things just need to be trashed. If the compressor is frozen, it's probably done. Perhaps you can revive it, but 15 years is a long run for an oil-less unit. Who knows the condition of the tank. Did you ALWAYS drain the air and any moisture in the tank. I doubt that, I am fussy and I can't claim yes to that question.
post #10 of 42 (permalink) Old 10-14-2016, 07:38 PM
Lucky Irish's Avatar
You made sure the outlet works?
Lucky Irish is offline
Help - where do you locate your dust filter? allthunbs Woodshop Dust Control 42 09-02-2018 10:29 PM
Hello and a question about air compressors Joe T CNC CNC Routing 1 11-07-2013 04:48 AM
Dylos Air Quality Monitor Group Buy BigJimAK The Bargain Bin 0 07-28-2011 12:46 PM
