need help fixing a drum sander - Router Forums
 4Likes
post #1 of 17 (permalink) Old 10-25-2016, 02:51 PM Thread Starter
kp91's Avatar
First Name: Doug
Default need help fixing a drum sander
My bride picked me up a very cool Power Kraft Drum/disc sander for my birthday. I had seen it on Craigslist for a long time at too high a price, but the guy lowered it while I was at sea and I "suggested" to my wife that she might want to see if it was available.
He gave her a lower price, plus a stand with an old Craftsman motor on it (which wasn't part of the original ad). He had cleaned it up, changed the bearings, and painted it, so it looks real nice. Unfortunately he polished the nameplate, so I can't narrow the age down any closer than 1948-1953.
The link shows a similar one, not mine. Mine is in the pic below. Montgomery Ward | Powr-Kraft - Publication Reprints | VintageMachinery.org
I quickly fell in love using this thing over the past few weeks, it is fantastic for sanding signs and scroll-sawn pieces. Unfortunately, this morning the drum liner fell apart (I guess after 60 years it is entitled to...). It looks like it was either thin cork, or a heavy duty felt originally, but hard to actually identify.
Anybody have any suggestions as what would work? I have seen thin self adhesive cork sheets before, I may just go that route.
I'll put some new pictures up when I get it on it's new table. The current table with the motor was for a table saw, so it's a little low.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #2 of 17 (permalink) Old 10-25-2016, 04:45 PM
That is fantastic, Doug, what a useful tool. You know, I have been a tool junky since I was able to walk and we regularly received the MonkeyWard catalogs,along with Sears. I have never recalled seeing that machine.
Does the table have a height adjustment Are the sanding belts one piece,or wraparound,and can you still get them?
Herb Stoops is online now
post #3 of 17 (permalink) Old 10-25-2016, 04:50 PM Thread Starter
kp91's Avatar
First Name: Doug
The table is adjustable with a cam lever, the original is missing, I have a cobbled-together adjuster that works. The sand paper is regular sheet sandpaper held in by a wedge clamp. This leaves a few degrees of the drum without paper, but it does a great job.
I went ahead and ordered some thin cork online today, if it works I will do a better job with the pictures. I love old tools, and this is a gem.
Herb Stoops likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 17 (permalink) Old 10-25-2016, 04:55 PM
When the tires on my 18" bandsaw fell apart and I found out that the place I bought didn't handle it anymore they suggested I go see an industrial belting outfit in Edmonton. They looked at the wheels and said they could lag on some of their belting and it should work as good as new. I tried it and they worked better than before. Waaay superior to the original tires, way tougher, and much, much longer lasting. It wasn't that expensive either, I think it was about $30 a wheel at the time. You might want to have a look at that option and I think it will probably be the final fix, at least from your point of view and from my experience.
post #5 of 17 (permalink) Old 10-25-2016, 06:58 PM
paduke's Avatar
I built A drum sander using a salvaged 4" roller from an 18" planer. I wrapped it with 4" adhesive backed neoprene.
kp91 likes this.
paduke is offline
post #6 of 17 (permalink) Old 10-26-2016, 01:00 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
never seen anything like that before. I cant figure out how you would use the drum without the wood getting out of shape as the table is one depth throughout.
Found a link with pictures though.
Photo Index - Montgomery Ward | Powr-Kraft - 84-TCE-2709 9" Drum / Disc Sander | VintageMachinery.org
sunnybob is online now
post #7 of 17 (permalink) Old 10-26-2016, 07:22 AM
Here's a link to a modern equivalent (less the disc sander).
Buy V-Drum and Flatmaster Drum Sanders Online - Stockroom Supply
They have a video showing the machine in action, flattening a chunk of walnut with some pretty wild grain.
tomp913 is offline
post #8 of 17 (permalink) Old 10-26-2016, 08:45 AM
First Name: Art
Did you ask in the vintage machinery forum?
mgmine is offline
post #9 of 17 (permalink) Old 10-26-2016, 08:46 AM
hawkeye10's Avatar
First Name: Don
I may be looking at the picture wrong but it reminds me of a Sand Flee which is still made. "I think"
SAND-FLEEŽ 18" Portable Drum Sander
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 17 (permalink) Old 10-26-2016, 11:16 AM Thread Starter
kp91's Avatar
First Name: Doug
If you set the paper just even with the table it takes a nice finish pass on a sign. If you have it set too high, you can scallop your workpiece if you push too fast
1 John 1:9
Fredericksburg, VA
kp91 is online now
question about V Drum Sander size Tom in indy Tools and Woodworking 3 03-09-2014 05:15 PM
Build Mobile base for a drum sander RickPr Tools and Woodworking 10 01-12-2013 10:15 AM
DS-1632 Drum Sander, Any Good. wm460 Tools and Woodworking 10 03-03-2012 04:28 AM
Thinking about making my own V drum sander... etivancic New Member Introductions 3 01-24-2009 05:37 PM
Drum sander help please? Birch Tools and Woodworking 6 04-19-2007 04:57 PM
