SHOP HACKS / bobj3 corner - Page 2 - Router Forums
 302Likes
post #11 of 133 (permalink) Old 10-28-2016, 06:59 AM
chessnut2's Avatar
Instead of using drawer slides I've used strips of counter top laminate instead a few times. One strip in the carcass and one on the bottom of the drawer runners. If they get sticky just rub some parafin wax on the drawer runners. I've also used this to fix the drawers on an old antique sideboard where the runners had worn into the carcass (wood on wood) causing the drawer front to drag when closing. The strips of laminate lifted the drawer back into position and made it slide easier and stopped the wear from getting worse.
Great idea, Charles. I put that in my memory chip (notebook). Thanks.
chessnut2 is offline
post #12 of 133 (permalink) Old 10-28-2016, 08:04 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
A picture says more than one thousand words
We, woodworkers are everywhere!!!
papasombre is offline
post #13 of 133 (permalink) Old 10-29-2016, 10:28 AM
A thin kerf 10 inch blade is not always the best choice. These tend to deflect if you apply too much angular pressure. It is hard, for example to get a really flat surface on a miter cut, so two ends join perfectly. Switch to a full kerf blade to all but eliminate the deflection. This is particularly important if you are cutting more than a couple of inch thick stock.
paduke, roxanne562001 and Garfman like this.
post #14 of 133 (permalink) Old 10-29-2016, 06:42 PM Thread Starter
paduke's Avatar
Red face i LUV CHUCK
I built a work table when time was abundant and money was tight. It was made from scraps and had rub drawer glides. As my shop grew these sticking drawers were almost abandoned until Chuck's post They slide now
Thank you
paduke is offline
post #15 of 133 (permalink) Old 10-29-2016, 06:46 PM Thread Starter
paduke's Avatar
Alexis
I have always admired your ingenuity this is just another example
paduke is offline
post #16 of 133 (permalink) Old 10-29-2016, 06:51 PM
Some great ideas, "hacks", tips and tricks.
Most, new to me...
A wonderful tribute to BJ and his immense contribution to the forum....
kp91, Gene Howe, DaninVan and 2 others like this.
Sydney, Australia
jw2170 is offline
post #17 of 133 (permalink) Old 10-31-2016, 05:37 PM
Here's a couple of sanding aids. One photo is small pieces of counter top laminate with various grits of sandpaper glued on. These are unbelievably handy for sanding small or narrow detail such as the fillets of a profiled edge. I keep them at my workbench so they are always close. I like attaching them with Lee Valley's fish glue. It stays water soluble forever so when the paper wears out I just wet them and in a couple of minutes they peel off so I can put a new one on. Regular glue works too but they are throwaway when the paper wears out. I dress the edges up with a file before gluing the paper on.
The other is a sanding jig for sanding things like wood edge banding added onto something like the melamine piece shown. Quite often when you trim these to size the edges have tool marks that need to be sanded off. Tis jig allows you to sand them without worrying about scratching the melamine or veneer up. Cut the sandpaper the same width as the wood banding. The right angle stop prevents you from going any wider than the banding is.
Name:	Sanding aids 001.jpg
Name:	Sanding aids 002.jpg
post #18 of 133 (permalink) Old 11-02-2016, 09:27 PM Thread Starter
paduke's Avatar
I use drawer liner Husky 18 in. x 100 in. Premium Solid Drawer Liner, Black-DTC130001 - The Home Depot for several shop tasks. It comes 18 in wide X 96 in. I cut it 3 ft and use it as a work surface cushion when finishing. It comes in handy when using an RT or TS as a work surface When done roll it up and put it away. It is also useful for pads on push tools. Its 1/8" thick and can be easily sliced into strips for spacers in raised panel doors.
paduke is offline
post #19 of 133 (permalink) Old 11-02-2016, 10:43 PM
I save the mailers that I get that are on the heavy cardstock. (get a lot of these right now from political candidates) I like to use them to make patterns with. The cardstock is heavy enough to make good, accurate patterns which I use to make heavier templates.
billyjim is offline
post #20 of 133 (permalink) Old 11-03-2016, 01:58 AM
jj777746's Avatar
Cut the legs off old track pants & slip your good handsaws in them,(held in place with rubber bands) before storing them away in the tool chest. Keeps rust off especially when living near the sea. Also,old bed sheets thrown over machinery when not in use helps with rust prevention.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
Many questions for new shop and hopefully the right place to post bclarknc Tools and Woodworking 24 07-13-2016 05:08 PM
Almost Finished My Wood Shop stan2602 Workshop Showroom 6 08-31-2013 11:21 AM
My shop -- Finally! rcp612 Workshop Showroom 13 07-18-2012 09:01 AM
New shop...where to put router...need two tables? Froglips New Member Introductions 1 06-12-2012 12:59 AM
Shop Organization Marco Tools and Woodworking 8 10-07-2011 06:57 AM
