Fine Dust - Router Forums
 20Likes
post #1 of 22 (permalink) Old 11-05-2016, 06:33 PM Thread Starter
First Name: Ed
Default Fine Dust
I check my Jet air filter and was surprised how much stuff floats around. The blue is the spot I cleaned on the filter the rest is the dust that just builds up.
RainMan 2.0 and gjackson52 like this.
herrwood is offline
post #2 of 22 (permalink) Old 11-05-2016, 06:38 PM
TWheels's Avatar
Dust particles of the size of bacteria gets through most filters including face masks. They can be very dangerous, whether they are fly ash from coal-fired power plants or wood particles from routers, table saws, planers, etc.
Vegetarian Arthritic Paraplegic Wannabe Routerologist
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #3 of 22 (permalink) Old 11-05-2016, 07:46 PM
RainMan 2.0's Avatar
I don't think you can have enough filtering . I should add a ceiling mount one while I'm at it .
If I take my mask off 5 minutes after the last cut , I start coughing . Goes to show you how much lingers in the air
TWheels likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 22 (permalink) Old 11-06-2016, 07:19 AM
kywoodchopper's Avatar
First Name: malcolm
Hi Ed, I have 2-Jet air filtrations devices mounted from the ceiling in my shop. The one farthest from the work area runs all the time, and I have to replace the filter more often. They do indeed pick up a lot of dust. I turn the other one on while I am running equipment and all the equipment have either a vac with a HEPA filter on the big dust collector. But I know dust is in the air.
I found the best way to mount the air filtration unit to the floor joists is to put 4-eye bolts in the floor joist and put 4-S hooks on them. Malcolm / Kentucky USA
OPG3 likes this.
kywoodchopper is offline
post #5 of 22 (permalink) Old 11-06-2016, 07:23 AM
OPG3's Avatar
First Name: Otis
This makes me wonder if anyone makes a wood dust filtration system that works using a fluid?
As a teenager, my first car was a 1963 Volkswagen Beetle. The air filter was simply a contraption which included a light interior coating of oil. Water wouldn't work because of its affect on humidity and then wood moisture and also tool corrosion, but how about vegetable oil? That VW air filter certainly picked-up a lot of dust and cleaning it out was a breeze (no pun intended).
DesertRatTom and RainMan 2.0 like this.
OPG3
Tweak everything!
OPG3 is offline
post #6 of 22 (permalink) Old 11-06-2016, 10:48 AM
I just bought a WEN filter unit. I can't really see any difference between it and the Jet, or for that matter, any of the other ceiling mounted filter boxes. It is very reasonable at about $125 right now. Filters are cheaper and same filtration as the Jet. https://smile.amazon.com/WEN-3410-3-...478446647&sr=1
I hung it up single handed to the roof beams in my shop. About 30 lbs, I put four hooks in, perched the unit atop a ladder and hooked the chains to the hooks on top and it was done.. 3 speed, 1, 2, 4 hour auto shutoff, 1/6hp blower (same as jet), painted black crinkle finish. Filters are cheap too. No shipping cost on Prime. I'll be getting a second unit for my garage where I mill my wood. My shop is pretty small (12x24) so I think one unit will do there, but a second couldn't hurt since I too start caughing if I take my mask off . Very happy with the purchase and it is nearly 5 stars on Amazon reviews. With Amazon, if it doesn't work right, send it back with no hassle.
Name:	wen air filter.jpg
TenGees, Roy Drake and RainMan 2.0 like this.
post #7 of 22 (permalink) Old 11-06-2016, 10:48 AM
Otis , this sounds like another invention in the making. Put me down for the first run please
OPG3 likes this.
post #8 of 22 (permalink) Old 11-06-2016, 11:02 AM
Seems to me you could just spray a light oil on a filter and get that effect. But without a filter medium of some sort a lot of large particles will get through. The dual filter idea is about trapping the large particles so they don't prematurely clog the small particle filter.
BTW, I'm a throat cancer survivor and I am happy to spend whatever I must to keep carcinogenic wood dust out of my throat and lungs. The lungs can't expel the really fine particles, so mask, dust collection and air filtration are not excessive. I read a couple of years ago that the EPA tests of small home shops show dangerous levels of fine dust, far more than the typical commercial shop.
OPG3 likes this.
post #9 of 22 (permalink) Old 11-06-2016, 12:37 PM
All of the early automotive air filters that I remember were oil bath. I think you filled it with whatever motor oil you were using down in the deep south but up north I would imagine it had to be light weight oil for winter. I think they worked fairly well but I think one of the biggest problems was that they tended not to get serviced often enough. It seems to me that when I worked at a service station in my late teens that we would check the filter to make sure that it had enough oil in it when we were filling the tank. That kind of dates me when you say you remember when they checked under your hood while your gas was being pumped for you.
K & N air filters still use oil but you spray the oil or at least wet a filter media with filter oil and it is captures particles efficiently while allowing more air to go through the filter. I first started using them on chainsaws working as a faller or bucker in the "bush" up here.
OPG3 likes this.
post #10 of 22 (permalink) Old 11-06-2016, 01:47 PM
JFPNCM's Avatar
First Name: Jon
Great reminder post, time to clean the filter in mine. No doubt the results will be the same as posted by ed.
Jon
JFPNCM is online now
new to all this! mapwd1702 New Member Introductions 23 06-06-2016 11:24 AM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 05:01 AM
Fine particle dust collector for shop sexton62 Shop Safety 14 07-07-2014 04:14 AM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 02:51 AM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 03:32 PM
