Masking tape trick - Router Forums
 18Likes
post #1 of 17 (permalink) Old 11-18-2016, 01:20 AM Thread Starter
RainMan 2.0's Avatar
Default Masking tape trick
You know I never would have thought of doing it this way . I tried lining up the blade with a square and could never get it right , so I'm going to try this to set up my miter saw
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 17 (permalink) Old 11-18-2016, 03:32 AM
JOAT's Avatar
First Name: Theo
Looks like it should work.
And, of course, I did it different. Hehehe
With my saw the table was just a tad off. Easy fix. I did use a square to line the blade up with the fence after I set the table where I wanted it, wasn't worried about it being 100%, just very close, because then I used JB Weld to make sure the table didn't move - was only interested in straight cuts. Then I tossed the saw fence. Made a new fence with a chunk of 2X4, and plywood to raise the top of the table. This gave me a very straight cut when I adjusted my 2X4 fence, and raising the table top gave me a wider cut. It wound up making a cut almost 8", and if I'd raised it a bit more would have been able to make cuts almost 10" wide. Sadly, later on the motor started smoking badly. Next time got a slider, big mistake, my wood fence wouldn't fit it, didn't like it anyway, and later sold it. So, now need to get the initiative to make a new fence, this time a bit higher.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #3 of 17 (permalink) Old 11-18-2016, 07:49 AM
First Name: Richard
Good idea, Rick. As Theo said looks like it should work.
Shop guy is offline
post #4 of 17 (permalink) Old 11-18-2016, 09:02 AM
tvman44's Avatar
First Name: Bob
That is a good idea.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #5 of 17 (permalink) Old 11-18-2016, 09:29 AM
MEBCWD's Avatar
I use a strip of 0.25" MDF and double stick tape. I cut through the MDF then remove one side so I have a good place to register my square when I set the fence.
MEBCWD is offline
post #6 of 17 (permalink) Old 11-18-2016, 09:51 AM
chessnut2's Avatar
This is a good one Rick. I have it saved now. And Mike: I like your idea that gives a positive stop to butt the square against. Thanks to both of you.
chessnut2 is offline
post #7 of 17 (permalink) Old 11-18-2016, 10:51 AM
Nickp's Avatar
First Name: Nick
Great idea...thanks for sharing, Rick...
Squares against the end result instead of the potential of blade deflection...
Because I carry mine around a lot I check it often...this will make that job easier...I normally cut a piece of wood and measure that...
Nick
Nickp is offline
post #8 of 17 (permalink) Old 11-18-2016, 11:02 AM
tvman44's Avatar
First Name: Bob
Mike I like your way even more. Good job.
Papa Bob
tvman44 is offline
post #9 of 17 (permalink) Old 11-18-2016, 01:19 PM
Knothead47's Avatar
Thanks for sharing the good video. I'm going to the shop and see what is adjustable on my saw. I have some projects on the clipboard and I should check my band saw and chop saw. Had a time getting the TS blade to 90 degrees. I found the mark on the front of the cabinet is hard to zero.......so I skipped relying on it and use a square to set the blade.
BTW, I don't recommend touching the blade while the cord is plugged in. Just my idea as Murphy's Law is still valid after all these years.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
post #10 of 17 (permalink) Old 11-18-2016, 09:02 PM Thread Starter
Mike I'm liking your idea .
I'm wondering if I clamp a piece of mdf to the table , slice it and then put the square against the secured piece and the fence to calibrate it
MEBCWD likes this.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
For Sale: Router Double sided Template Tape woodman79 Woodworking Classifieds 35 07-10-2018 06:27 AM
Luthier's Masking Tape and Superglue Trick David Dickson Tools and Woodworking 12 08-06-2016 11:19 AM
My New Favorite Tape Measure DonkeyHody Tools and Woodworking 36 12-07-2015 01:15 PM
Testing Peachtree double-sided tape Gaffboat Tools and Woodworking 22 11-17-2014 10:05 PM
