Wood Glue - Router Forums
 4Likes
  • 3 Post By DesertRatTom
  • 1 Post By hawkeye10
post #1 of 8 (permalink) Old 11-25-2016, 02:50 PM Thread Starter
Default Wood Glue
if you get glue on the face of something you are going to stain, if you wipe it off and sand will the stain take, thanks
Sent from my SM-G930V using Tapatalk
bill.marshall.94 is offline
post #2 of 8 (permalink) Old 11-25-2016, 03:24 PM
The stain may take but not in the same way that the wood will where there was no glue unless you sand enough to get past it. The wet cloth dilutes the glue and drives some of it into the wood pores which at least partially fills them. The one exception is a water soluble glue like Lee Valley's fish glue which will wipe almost completely off. I like to use it when I repair things like a split in the grain at an edge.
Sometimes it is advisable to pre-finish the wood before you glue but that can be tricky too because if you are using an oil base stain then you don't want to get it where the glue is going or it may interfere with the glue bonding properly.
post #3 of 8 (permalink) Old 11-25-2016, 07:11 PM
For picture frames, I pre finish because it is impossible to keep the glue off the face. It takes a lot of sanding to get that glue off and get down the bare wood. I apply it carefully and away from the face. After assembly, I usually use wipe on poly to give it the gloss I like. To strengthen miter corners, I generally use splines.
JFPNCM, Herb Stoops and hawkeye10 like this.
post #4 of 8 (permalink) Old 11-25-2016, 10:04 PM Thread Starter
is that why it's better to just leave the squeeze out, then remove it when dried with a chisel.
post #5 of 8 (permalink) Old 11-26-2016, 01:53 AM
Yes. It affects a much smaller area.
post #6 of 8 (permalink) Old 11-26-2016, 06:54 AM
hawkeye10's Avatar
First Name: Don
If it's possible you can use blue painters tape and let the squeeze out get on it.
JFPNCM likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 8 (permalink) Old 11-26-2016, 09:33 AM
Honored Member
First Name: pat
Test before applying the finish to the whole thing.
Quillman is offline
post #8 of 8 (permalink) Old 11-28-2016, 05:18 AM Thread Starter
I'll remember that next time, I stained it and not to good because of glue. well live and learn, I'll sand it then paint it...will have to practice gluing..thanks for the painters tape tip
New to wood working and to this forum. jaithran New Member Introductions 9 11-25-2014 01:50 AM
Maloof Inspired rocking chair build TwoSkies57 TwoSkies57 Gallery 235 07-13-2014 06:29 PM
How I Found Free And Inexpensive Wood Over The Past Three Months tkleff Starting Off 51 12-16-2012 08:40 PM
glue plastic to wood Kelly Rittgers Jigs and Fixtures 11 02-14-2011 03:22 AM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 06:58 PM
