Workbench (Cont'd) - Page 3 - Router Forums
 27Likes
post #21 of 24 (permalink) Old 06-24-2017, 05:48 PM Thread Starter
Guest
The top is partially completed now...all but the last picture shows the plywood inverted from its final orientation, i.e., the bottom of the top. I began with my biscuit joiner, which I have not used for a couple years, and the table saw, circular saw and miter saw. I cut the plywood to size using the circular saw and table saw and set it upside down on the workbench frame. With the biscuit joiner I cut slots in the plywood spaced about every 8-10 inches. Then I mitered the 1X2 edge banding (3 edges of the top), set them with the bottom edge up and cut corresponding slots for the biscuits. Then using glue, biscuits and 18 gauge pin nails (with my Harbor Freight pneumatic pin nailer), I set the edge banding in place and let the glue dry for a couple hours. Then I oriented the top in its final position and fastened it to the frame with six #10 X 2" screws. As you will see in the last picture, the MDF has not yet been added. I will have to cut it to size and slide it into the frame. If necessary I'll stick it to the plywood with double sided tape. The edge banding will be flush with the top of the MDF (or if it isn't exactly flush I'll finish it with the plane or the router with a pattern bit with bearing. I'll finish that in the next day or so. Yet to be done is the bottom shelf (I cut an old scrap piece of particle board for temporary). The side vise is still in the planning stage and may not be added for a while. Just as an aside, the work I did with the restored plane was perfect. The top of the frame is now level and straight, as is one of the shelf cross members, which was about 1/8" proud.
Here are today's pics:
163481 is offline
post #22 of 24 (permalink) Old 06-25-2017, 01:23 PM Thread Starter
Guest
And here is the top with the MDF sized and installed. I did use a couple 8" pieces of carpet tape to stick it down to the plywood. In the pics you can see that the end where the Moxon vise is installed is not edge banded. I will dress that edge up with hardwood when I face the vise with hardwood jaws. And in the last pic you can see my shop-built disc sander. Just a meaningless observation: that bench with the sander and compressor on the shelf is about as heavy as my table saw. It ought not to wiggle around much while I'm working.
163481 is offline
post #23 of 24 (permalink) Old 06-26-2017, 11:52 AM Thread Starter
Guest
I'll guess everyone is wondering about the purpose of the Irwin clamps on the benchtop. The MDF had just a little bow in it and I clamped it down on the carpet tape to see if it would straighten itself out. I'll leave the clamps on for a few days and if there is still a bow I'll do something else. I don't want to permanently fasten the MDF to the plywood so I can easily replace it if/when it gets beat up. I suppose I could do flat-top screws with a deep counterbore. I'll have to give it some thought.
163481 is offline
post #24 of 24 (permalink) Old 06-29-2017, 12:59 PM
RainMan 2.0's Avatar
Looking good Chuck . Very heavy duty
163481 likes this.
Ok ,I never insulate
RainMan 2.0 is offline
Workbench Tenon Length? Gaia Project Plans and How To 8 05-16-2017 09:24 AM
My first Workbench Burke Show N' Tell 11 10-15-2011 10:25 PM
Workbench / Router table Jusaquikie Table-mounted Routing 14 03-15-2011 10:19 AM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 02:54 PM
Workbench I Microsuffer Microsuffer's Follies 8 03-16-2009 11:46 AM
