Dust Collector Impeller Question - Router Forums
 4Likes
post #1 of 14 (permalink) Old 06-26-2017, 10:20 AM Thread Starter
Contributor of the Month
Default Dust Collector Impeller Question
I read a magazine article that recommended replacing the Dust Collector's original impeller with a larger impeller for better performance. Anybody ever try this?
JIMMIEM is offline
post #2 of 14 (permalink) Old 06-26-2017, 10:29 AM
Bob Adams's Avatar
First Name: Bob
I swapped out the impellor of my Harbor Freight DC for a Rikon. I a very happy with the results.
furboo likes this.
Bob Adams is offline
post #3 of 14 (permalink) Old 06-26-2017, 10:35 AM Thread Starter
Was the Rikon larger than the HF?
Is it an easy process? Also, how to determine size, specs, etc?
JIMMIEM is offline
post #4 of 14 (permalink) Old 06-26-2017, 11:00 AM
Bob Adams's Avatar
First Name: Bob
The Rikon is larger and the fins are reversed. It was easy. I did a full review here: https://www.woodtalkonline.com/topic...rikonstein-dc/ . Let me know if you have any questions.
Ed3443 likes this.
post #5 of 14 (permalink) Old 06-26-2017, 06:02 PM
A number of people have done that conversion. If you do it, make sure you have a chip collector of some sort before the DC unit to keep potentially destructive bits and pieces from hitting the impeller. Also, when you contact Rikon, it is recommended you not mention you're making an HF conversion.
MEBCWD likes this.
post #6 of 14 (permalink) Old 06-26-2017, 06:48 PM
Bob Adams's Avatar
First Name: Bob
I had heard that rumor also, it didn't sound right to me. When I called to order the impellor I asked the sales rep about it, and he laughed. Said that rumor had been around for years, and then he charged me $119.00 and shipped the impellor.
post #7 of 14 (permalink) Old 06-26-2017, 07:51 PM
Tom may be right about why the standard impeller is so much smaller than the housing it fits in. I've had small strips up to about 6" long go through mine and if the clearances were tight that might not have gone very well. MafoElfen also did a refit a few years ago on his DC but I don't remember all the details. I know Mike was a pretty good metal smith so his may have been a little more complicated but I recall him saying that it made a huge improvement.
post #8 of 14 (permalink) Old 06-27-2017, 10:14 AM
I think it was Tonto and another couple of guys who did some air flow measurements comparing the HF impeller to the Rikon, and the numbers were significantly increased with the Rikon device. They also discussed that they had to take the unit open and may have had to sand the shaft down slightly to fit the impeller properly (not positive about that). They did mention is was a tight fit. They also mentioned that the run up took a little more time, and it definitely took awhile for it to come to a stop. I'm not much of a mechanic, and I'm very satisfied with the HF performance as is.
post #9 of 14 (permalink) Old 06-27-2017, 05:22 PM Thread Starter
I have a Delta 1 1/2 HP model 50-760 Dust Collector. Do I have to dismantle it to check the impellor and see if it is upgradeable? I have a Thien separator attached to it.
JIMMIEM is offline
post #10 of 14 (permalink) Old 06-27-2017, 08:51 PM
Bob Adams's Avatar
First Name: Bob
I am not familiar with your Delta, but I did look up the specs, and found that the impellor size is 11 1/2". That is about the size of the Rikon impellor. Personally I would not bother.
Herb Stoops likes this.
Dust Deputy Cyclone Dejure Tool Reviews 3 06-16-2014 09:46 PM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 04:39 PM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 02:51 AM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 03:32 PM
Dust Collection Question deck99 Table-mounted Routing 7 04-25-2008 12:11 PM
