Drill Press broke - Router Forums
post #1 of 14 (permalink) Old 01-17-2009, 04:18 PM Thread Starter
First Name: Steve
Default Drill Press broke
The chuck came out of my Delta drill press a few minutes ago (table top, but a heavy one).
Scary.
The part that came off ( the chuck) appears to be just fine but I need to re-attached it. It has a morse taper I think. I am wondering if I should put some expoxy or something else on the inside of the chuck to prevent that from happening again.
Metal to metal glue? Choices? Or do I have this wrong.
Steve Bolton
S Bolton is offline
post #2 of 14 (permalink) Old 01-17-2009, 04:27 PM
Hamlin's Avatar
First Name: Ken
HI SB,
NO, don't glue it. These are made purposely. Just realign it, use a block wood on the table, bring down the arbor, (just like you're drilling). This will press the chuck back into place. Make sure there's no burs, if needed, clean the chuck before pressing back into place.
It's difficult to find them but, they are out there on the market... there are drill bits specifically designed to just fit into the very space that your chuck does. They are only pressed into place. It's why, you have that little wedge type tool.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 14 (permalink) Old 01-17-2009, 04:37 PM Thread Starter
First Name: Steve
Saved by your reponse and the Delta manual I downloaded. Use a rubber mallet and wood to put it back in place it states. I will try your method.
What do you clean it with?
SB
S Bolton is offline
post #4 of 14 (permalink) Old 01-17-2009, 04:39 PM
Hamlin's Avatar
First Name: Ken
I use just a normal degreaser. Again, just press it back into place.
Ken
"A VETERAN"
Hamlin is offline
post #5 of 14 (permalink) Old 01-17-2009, 04:40 PM Thread Starter
First Name: Steve
Got it.
Many thanks.
sb
S Bolton is offline
post #6 of 14 (permalink) Old 01-17-2009, 05:06 PM
Ken's method works quite well. The arbor dropped out of my Delta a good while age, pressed it back in (instead of whacking it) and has been tight ever since.
a1tomo is offline
post #7 of 14 (permalink) Old 01-17-2009, 11:58 PM
The most common reason for one of these chucks coming loose is letting it return too fast and bumping into the stop. With the temp in my garage hovering around 30 my chuck came loose as well. I write that off to being outside the normal operating temp zone. This is to say... it happens, no biggie.
post #8 of 14 (permalink) Old 01-18-2009, 02:39 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
These are Jarno tapers not MT (Morse tapers). If it came loose it may have scored the socket. Any marks on the socket will cause the mating taper to come out again so make sure that as well as cleaning it any burrs are removed.
istracpsboss is offline
post #9 of 14 (permalink) Old 01-18-2009, 09:46 AM Thread Starter
First Name: Steve
Everything looked clean, so I put it back in using the methods described here and I drilled away last night.
SB
S Bolton is offline
post #10 of 14 (permalink) Old 01-18-2009, 10:06 AM
hi SB
Here's a why it came out,,,the norm,, when it's cold the steel will shrink,just a little bit and with a small tap/bump it's out...some come with a key to remove them but some don't, so to say if you need to replace down the road and you will,rap it with a cold pack and wait about 10 mins.or so then with a light tap you can replace it...I have seen some take a hammer and nail the chuck asm. and trash the drill press with just one blow..
A heat gun is your friend when you want to put it back on without using a sledge hammer and a block of wood..
SB
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 7 07-15-2006 11:20 AM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 3 03-25-2006 10:43 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
