Mortise? - Page 4 - Router Forums
 16Likes
post #31 of 33 (permalink) Old 08-16-2017, 06:07 PM Thread Starter
Guest
Look back at the picture of the underside of the bench. I'll refer to various locations on the pic. The fixed jaw (that you see in the upper right corner) is fastened to the bench skirt with two #10 2" screws through the jaw and into the skirt. The rear support is fastened between the side skirt (top of the pic) and the cross-member (bottom of the pic) with two each #10 2" screws through the skirt into the end of the rear support, and through the cross-member into the other end of the rear support (where the broken shim is seen).
The threaded flange of the bench screw is fastened to the inside surface of the bench skirt with #10 2" screws, the heads of which you can see in the pic. That's what references the position of the movable jaw.
What is missing is the front plate, which will be split in half and have a centered 3/4" hole that will capture the bench screw in the 1/4" groove (visible in the picture below) just behind the handle. That will pull the movable jaw out and the other side, as you observed, will push it in.
The 1/4" thick front plate may be inlaid into the front jaw (if I get ambitious -- otherwise it'll be surface-mounted) and there will be a 1/8" recess just behind the plate to accommodate the 1 1/4" diameter flange on the bench screw behind the plate.
The bench screw was obtained from Grizzly for $33.00 plus shipping. There are other options, including an Acme-threaded hardwood dowel, examples of which can be found on the Internet.
Hope that clears it up and I apologize for not making it more clear.
And I'm vacillating between a 3 1/2" round plate (made of a 1/4" thick fender washer) or a 6" long by 3" high plate made of 4 gauge steel...IF I can find a machine shop that will do such a small job.
163481 is offline
post #32 of 33 (permalink) Old 08-17-2017, 05:15 AM
vindaloo's Avatar
First Name: Angie
Ah, got it. Thanks Chuck, it's all clear now.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #33 of 33 (permalink) Old 08-17-2017, 09:58 AM Thread Starter
Guest
The final analysis of this project is:
A few days ago I was on the catalog pages of Grizzly's web site and had occasion to look at their offering of vises...of which there are pages and pages. I found a woodworking vise frame (H7788) to which one adds his own wooden jaws for $57.95. Had I learned earlier of the availability of this vise frame it would have saved me a lot of time and a considerable sum of money.
Do I regret designing and building my own vise? No. Even though I did not achieve my purpose of designing a vise that anyone could replicate inexpensively, there is a satisfaction derived from designing and executing something that works as intended regardless of the effort and cost involved. But I could have used the extra cash for....
(Added some time later) Just as a final, final thought (the basis of which will be kept private), this was never a scam or money-making scheme. There were never going to be any plans for sale or kits to replicate this vise. It was strictly and honestly as posted.
With that, I'm outta here.
163481 is offline
Type Of Mortise Chisel To Square Slot Gaia Tools and Woodworking 50 08-29-2011 02:17 PM
Squaring Up Mortise And Glueing M & T Gaia Starting Off 4 08-03-2011 03:24 PM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
TS / Router / Mortise Combo PART1 kolias Jigs and Fixtures 1 05-04-2009 06:52 AM
Rolling Mortise Jig - the test simplenik Table-mounted Routing 9 07-23-2007 10:54 AM
