Kitchen Cabinet Doors - Router Forums
post #1 of 7 (permalink) Old 01-18-2009, 01:28 PM Thread Starter
Default Kitchen Cabinet Doors
What is usally used for making cabinet doors, i am mostly concerned with the thickness of the wood. I mean can the rails, stiles and the rasied panel all be the same thickness or does the rasied panel have to be thinner
Thanks Kevin
TF-Kevin is offline
post #2 of 7 (permalink) Old 01-18-2009, 01:40 PM
HI Kevin
The norm,,they are all the same thickness , but they can be anything you want to use,,,it comes down to what type of look you want to end up with.
You will need a R&P router bit set that must be use in the router table
Don't forget you are not making a front door for the house,keep them light looking..but strong they will need to last for years and years..
Thanks Kevin
post #3 of 7 (permalink) Old 01-18-2009, 03:17 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Glad to have you aboard Kevin. Welcome to the forums.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 7 (permalink) Old 01-18-2009, 05:14 PM Thread Starter
Can i router 3/16 of the back of the rasied panel so the front of the panel will be flush with the front of the rails and stiles. But again the back will also be flush, would that be ok
Thanks Kevin
TF-Kevin is offline
post #5 of 7 (permalink) Old 01-18-2009, 05:31 PM
Hi Kevin
The panel bit with a back cutter will do all the work for you,,all the parts to the doors will be flush with each other, front and back ..
Thanks Kevin
post #6 of 7 (permalink) Old 01-18-2009, 11:55 PM Thread Starter
I want to thank you for your info, it was alot of help, i didn't know about the raised panel bit with the back cutter, but i did know about about the other bits. thanks again
Kevin
TF-Kevin is offline
post #7 of 7 (permalink) Old 01-19-2009, 10:44 AM
curiousgeorge's Avatar
First Name: George
Welcome, Kevin. Just wondering... If you want the panel flush front and back. Why not just use a solid door?
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 32 03-24-2013 03:26 PM
Water Damaged oak cabinet doors joeboxer JoeBoxer's Gallery 20 09-26-2011 10:28 PM
Shaker cabinet doors (Newbee) williams94 Table-mounted Routing 14 08-24-2011 10:55 PM
Need a table to do cabinet doors dynamowhum Table-mounted Routing 4 12-07-2008 10:07 PM
kitchen cabinet doors help puretrick Tools and Woodworking 15 06-05-2005 04:28 PM
