table saw tollerance question - Router Forums
post #1 of 12 (permalink) Old 01-25-2009, 10:32 PM Thread Starter
First Name: pascal
Default table saw tollerance question
I just picked up and set up a Ridgid TS2410LS portable table saw. quick question on the extension tolerance:
with the extension in I have the extension perfectly level, at full out the front of the extension is near perfect, however, the rear is down 1/8th
Is this acceptable for a table saw in this price range ($450)?
thanks!
Last edited by blurry; 01-26-2009 at 01:10 AM. Reason: added pictures, corrected measurement due to innacurate measurement device (doh!)
blurry is offline
post #2 of 12 (permalink) Old 01-25-2009, 10:54 PM
dovetail_65's Avatar
First Name: Dovetail
I had that saw. I never measured but I never had a problem with it either.
If you make cuts and it does not effect them then I would not worry about it, but it seems to me something may a little loose on the back. Can you wiggle it up and down?
A 1/16" is a lot for less than a 2 foot span though. If it is new maybe you can try another one ot go look at the one on display to see if it is any different.
dovetail_65 is offline
post #3 of 12 (permalink) Old 01-25-2009, 11:12 PM Thread Starter
First Name: pascal
The back rail was loose, I did tighten it up and check for adjustment, but there isn't any. Good idea to check a floor model, maybe I'll do that on the way home tomorrow.
figures, that was the last thing I adjusted!
blurry is offline
post #4 of 12 (permalink) Old 01-25-2009, 11:15 PM
levon's Avatar
First Name: levon
pascal,
are you talking about a wing extension?
sorry , i see now.
levon
levon is offline
post #5 of 12 (permalink) Old 01-26-2009, 12:55 AM Thread Starter
First Name: pascal
yeah, the wing extension. I just waled out to the garage and re-measured and the gap is 1/8th - turns out I have a very inaccurate spark plug gauge (checked with digital caliper).
I'm a little on the perfectionist side - however I try to be realistic - this is not a $4k table saw - 1/8th seems like quite a bit though...
blurry is offline
post #6 of 12 (permalink) Old 01-26-2009, 08:10 AM
scotirish10's Avatar
First Name: Ronald
My 2 cent's worth: The drop could cause a problem if the wood being cut is heavy enough. If it is extended over far enough you will bibd the blade or have a cut not square.
scotirish 10
Work safe: Remember the only 'SAFE' power tool in the shop, is the one with the plug pulled out of the socket!
If you have an open mind is there a chance your brain might fall out?
scotirish10 is offline
post #7 of 12 (permalink) Old 01-26-2009, 08:14 AM
First Name: Richard
Hi: Even at $450. I think it should be a lot closer to perfect than what it is. It would seem that the adjustment for the rear end of the extention is out of whack.
Perhalps the bolt hole to attach it to the saw is off a bit. Is it possible that the hole could be enlarged to allow more adjustment? I would also check the extention for warping, from front to back. Hope this helps Woodnut65
Woodnut65 is offline
post #8 of 12 (permalink) Old 01-26-2009, 09:09 AM Thread Starter
First Name: pascal
I loosened up the rear four bolts and moved the rail up a bit. Only thing that bugs me is that the rear rail is flush to the T-Track, while the front is down 1/16th. Something doesn't seem right about that. checked everything in both directions for level and it checks out.
aside from this, I'm very impressed with the saw for the money!
blurry is offline
post #9 of 12 (permalink) Old 01-26-2009, 12:54 PM
rwyoung's Avatar
First Name: Rob
I don't have this saw but there are a few guys over at www.ridgid.com that do. Find the link at the top of the web page for the forum and then start you searches. If you haven't already been there, give it a look-see.
rwyoung is offline
post #10 of 12 (permalink) Old 01-26-2009, 05:37 PM
Ghidrah's Avatar
First Name: Ronald
Is the table extension flush to the top of the rails that hold it?
If so the rails are likely down check them with a metal yard stick, framing square or some other reliable as-long-as-possible straight edge. When I was installing my extension it was higher and the fence smacked it.
Flush the Ext. to the rails and then the rails to the table. If the Ext. is floating, you might consider a support leg under the end.
Ghidrah is offline
Table Fence Question Bob N Table-mounted Routing 15 11-19-2009 05:33 AM
a member of 2 years but never posted a question. Here goes...(PC 695/bosch table) routerron New Member Introductions 4 09-19-2006 11:33 AM
Question with making a router table edbd1100 Table-mounted Routing 8 03-06-2006 09:56 PM
Router table insert question simplenik Table-mounted Routing 4 02-15-2006 11:18 AM
