thickness planer mounting - Router Forums
post #1 of 5 (permalink) Old 05-08-2005, 07:55 AM Thread Starter
Default thickness planer mounting
i am in the final stages of mounting my thickness planer to the stand i made. the plans are calling out for a bolt/t-nut assembly. i have 5/16" x 2" bolt that I am using to mount it. I have never used t-nuts before and was wondering what size do i buy and how do they work? i was gonna buy normal washer and nut sets but i figured there was a reason behind them specifying T-NUTS. can anyone help me out here?
thanks
shawn
reds_21 is offline
post #2 of 5 (permalink) Old 08-07-2005, 05:56 PM
Glenmore's Avatar
First Name: Glenmore
Shawn I just simply used 3/8 lag bolts and a washer to screw down my dewalt 734 planer right to the work station. So how did you make out with it.
Glenmore is offline
post #3 of 5 (permalink) Old 08-07-2005, 08:05 PM
Shawn,
I have a DeWalt 735 planer and I used regular lag bolts like Glenmore and it's as solid as it can possibly be. Good Luck with yours.
Bill
Billwolley is offline
post #4 of 5 (permalink) Old 08-07-2005, 09:02 PM
Shawn, the reason the plans call for the T-nuts is they stay attached even if you dismount the planer.(for quick alignment) Using regular nylon locking nuts and washers would be fine. The way T-nuts work is you drill a hole, slip the T-nut in and secure it with small screws. You can purchase T-nuts at any hardware store or HD, etc...
post #5 of 5 (permalink) Old 08-07-2005, 09:14 PM Thread Starter
thanks guys, i should have updated this thread awhile ago but,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,i have had that thickness planer stand done for awhile now. once i bought the t-nuts and screwed them in i saw how they worked. quite easily as a matter of fact.
thank you guys!!!!
reds_21 is offline
Planer Jigs.... challagan Tools and Woodworking 8 04-05-2013 10:52 PM
used planer reikimaster Tools and Woodworking 19 04-22-2012 02:12 AM
Thickness Planer Sled pmspirito Jigs and Fixtures 7 11-08-2007 12:44 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
Thickness Planer Wood Defect....... reds_21 Tools and Woodworking 3 05-15-2005 07:47 AM
