Planer dust port - Router Forums
post #1 of 21 (permalink) Old 05-08-2005, 02:15 PM Thread Starter
Julie's Avatar
First Name: Julie
Question Planer dust port
Hi
Can someone please tell me what is used to connect the planer to dust collection? The opening that the wood shoots out of is long and narrow and I haven't been able to find a dust port that fits that. Do you make your own, or is there somewhere to buy the planer dust ports?
~Julie~
Julie is offline
post #2 of 21 (permalink) Old 05-08-2005, 02:29 PM
First Name: Richard
Hi Julie: It depends on the make of the Planer. Most of the ones I have seen offer a
adapter to allow the hook-upof a vac, with either a 2 1/4" (shop vac) or a 3 or 4" for
a vac system. I had a Grizzly 15" planer and had to order it separate as an add-on.
The De Walt I have now came with the adapter. What type do you have??
Woodnut65
Woodnut65 is offline
post #3 of 21 (permalink) Old 05-08-2005, 04:05 PM Thread Starter
Julie's Avatar
First Name: Julie
I have a King planer. Didn't see any mention of the adapter in my owner's manual, so wondered if there was a generic one.
~Julie~
Julie is offline
post #4 of 21 (permalink) Old 05-10-2005, 09:16 AM
reible's Avatar
I have the same problem.... guess I should try to solve it someday. When I got my planner they had a dust collector attachment listed but since it was a new model they did not have it in stock "yet". A couple of years later I was told they didn't have them "any more"???? My guess is they never made them.
My planner is sitting on a shelf and I'm not using it much because of the hassle of getting it out to use. I have a stand I got for it but mounted my drum sander on it..... Maybe by this fall I will get a stand for the sander and get the planner back into use. And then deal with the chip collector issue.
I haven't seen attachments from other units that look like they would fit mine so it might be you will have the same problem. Making one is another option or maybe adapting some other makers???
Over the winter I made a sheet metal "shoot" for my jointer so at least most the chips get out from under it. I want to make an adapter to a hose at some point but at least what I did do was an improvement.
If you do make one please post some pictures I could use some ideas.
Ed
reible is offline
post #5 of 21 (permalink) Old 05-10-2005, 09:54 AM Thread Starter
Julie's Avatar
First Name: Julie
Hi Ed: I can't believe you don't use your planer! I use mine because I love taking rough wood and changing it. I usually use the wood shavings in my garden as mulch or in my dog houses as bedding. But boy, does the planer ever shoot out a lot of it, all over the shop! So that's why I need the planer dust hood and I did find one at the King website. http://www.kingcanada.com/Accessories.htm?ID=382 Now just to find a place to buy one. Maybe the local woodworking shop where I bought all my tools. I'm sure they either will have one, or order one for me.
~Julie~
Julie is offline
post #6 of 21 (permalink) Old 05-10-2005, 10:30 AM
reible's Avatar
Yea I'm sort of out of the loop when it comes to using my planner..... and as you said they do make a lot of chips and without a chip collector things get messy..... So it has been on the shelf a lot.....
The crazy thing is the dust chute you pictured looks a lot like what mine should look like..... In fact the planner it belongs to looks a lot like mine but a little newer..... now could you check the mounting holes on yours? Mine measure about 330mm. Mine says it is from Taiwan?????
Ed
reible is offline
post #7 of 21 (permalink) Old 05-10-2005, 10:44 AM
Default Homemade planer dust port.
Julie,
I believe this setup was in ShopNotes (I got the info from a friend). A bit of Masonite, some scrap 1x2's and some screws and it worked like a champ.
After this was made I finally got a Dust Collector so it has been modified for a 3" hose which helps even more. What used to be a 10 minute cleanup and vacuum job after planing is now a 'pftttt -- I'll vacuum that up next week' deal.
NewMontanaWorkshop is offline
post #8 of 21 (permalink) Old 05-10-2005, 07:11 PM Thread Starter
Julie's Avatar
First Name: Julie
Was there a website there in your message, Stan, or a photo? I got the old red X in a box thingy. Ed, do you want me to measure my planer? By 330mm you mean where and what, please? I will gladly go and do that for you as soon as I know what to measure. :S
~Julie~
Julie is offline
post #9 of 21 (permalink) Old 05-10-2005, 07:43 PM
~Julie~
Hmmm, not sure why that happened... but here is the link to the picture.
http://bt3gallery.fhauto.com/view_ph...d=DSC00002_009
post #10 of 21 (permalink) Old 05-10-2005, 08:55 PM
reible's Avatar
I see a picture for what that is worth.
Julie my planner has a chip deflector that I think you take off and add the chip pick-up, it has two allen head screws that remove it and I'm guess that they are used to mount the port.... They are on the out-feed side of the machine. Two other holes are tapped into the piece so maybe I'm wrong about how it mounts??? These are 240 mm apart and could be how it is mounted???? I'll have to drag it out in the light to see if I can see what should happen..... Maybe I'll try and find the manual.... as a last resort I can check that.
Ed
reible is offline
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 11:29 AM
Big time dust problem lnagel Table-mounted Routing 5 05-18-2009 07:58 AM
Practacle Dust control for "part timers" bob oswin Tools and Woodworking 34 07-31-2008 08:26 PM
Dust question Qstick Tools and Woodworking 37 03-05-2007 04:46 PM
dust port bunkie Table-mounted Routing 3 02-12-2006 09:07 AM
