how to cut small squares in panel - Router Forums
post #1 of 11 (permalink) Old 01-27-2009, 02:23 PM Thread Starter
First Name: Ned
Default how to cut small squares in panel
Greetings to all --
I have a project that entails creating a series of panels: left, right and center. The left and right panels are 20"wide x 28" tall, and the center panel is 48" wide x 28" tall.
Each of the panels will need to have the same exact "look", which consists of cutouts that are approximately 1 7/8" square.
I'm wondering what method those of you who are more experienced than I would recommend to do this.
I thought a router might be a good solution, but I'm not sure how to create a template that has the squares. Are there router bits that leave a 90 degree corner when cutting?
To prove the initial concept, I thought of using soft wood, i.e. pine, but ultimately the finished panels will need to be hard wood.
Final thickness is approximately 1/2".
Thanks in advance for any suggestions.
Ned Otter
NedOtter is offline
post #2 of 11 (permalink) Old 01-27-2009, 02:39 PM
HI Ned
Sounds like a good job for a GOOD jig saw
Originally Posted by NedOtter View Post
Greetings to all --
Ned Otter
post #3 of 11 (permalink) Old 01-27-2009, 03:08 PM
AxlMyk's Avatar
You could use a template, then a corner mortising chisel to square the corners.
http://www.rockler.com/product.cfm?p...orner%20chisel
AxlMyk is offline
post #4 of 11 (permalink) Old 01-27-2009, 03:22 PM Thread Starter
First Name: Ned
Gents - thanks for the advice.
Bob J. - my experience with two Bosch jigsaws leads me to believe that the blade will deflect, making it difficult to cut squarely.
Or do the better jig saws handle deflection well?
NedOtter is offline
post #5 of 11 (permalink) Old 01-27-2009, 03:27 PM
HI Ned
The Bosch will do it just fine, the key is the Blade,,,Bosch makes some blades that will not deflect ,if fact they are hard to turn,, take a trip down to HD/Lowes and you will see them hanging on the wall..
http://www.amazon.com/Bosch-T345XF-P...091946&sr=1-36
http://www.amazon.com/Bosch-T234X-Pr...3091754&sr=1-2
http://www.amazon.com/Bosch-T101A-4-...3091754&sr=1-4
http://www.amazon.com/s/ref=nb_ss_hi...blades&x=0&y=0
post #6 of 11 (permalink) Old 01-28-2009, 09:33 AM
Ralph Barker's Avatar
First Name: Ralph
I think I'd use a jig saw for the rough cuts, too, and then refine the edges with a router and an edge trimming bit and a template, along with a hand chisel for the corners.
- Ralph
Ralph Barker is offline
post #7 of 11 (permalink) Old 01-28-2009, 09:43 AM
Hi Ned
Just one more way,, if you are handy with your tools,,and a grinder (dremel) and a good file, find some square tubing in the shop and make a punch,,grind it just like a chisel but on the inside of the tubing only ..then make a jig to hold your hyd. bottle jack and punch out the 1 7/8" squares.(out some old pallets 2" x 4" oak stock) .( think of it like the gasket punches sets just bigger and square),,,,,punch,,, Like the ones below just square
If you have a bearing press then you are set for sure..
http://www.harborfreight.com/cpi/cta...temnumber=4711
http://www.harborfreight.com/cpi/cta...emnumber=33497
post #8 of 11 (permalink) Old 02-02-2009, 12:00 AM
First Name: Drew
If the squares are in a grid, do it as part of your glue-up. For example, put in a full-length piece for a solid column, then short stubby pieces to make a column of squares, full-length piece, etc.
Or compromise on the design to ease production. Allowing for a 1/8" radius will let you use a 1/4" router bit in a template.
You can use strips of wood and double sided tape to guide a router to quickly cut a template.
No. You'd need to square up the corners with a chisel.
Drew Eckhardt is offline
post #9 of 11 (permalink) Old 02-02-2009, 08:37 AM
Bosch 1590evs and the 1591 have these dohickeys that keep the blades straighter than before. People seem impressed. Just ebayed one myself so I can't speak form personal experience yet.
Pherdnut is offline
post #10 of 11 (permalink) Old 02-05-2009, 04:57 PM
Ghidrah's Avatar
First Name: Ronald
Ned no offense, but your question lacks detail.
The number and spacing of the 1 7/8sq cutouts per panel, how they line up, are the panels going into stiles and rails cut by you or just screwed or glued to another surface?
A 1/4" router bit will still cut, (albeit small) rounded corners that you could clean up, (if adamant) with the a corner chisel but for continuity you'll need to make a jig.
A jig saw for a couple of cuts maybe but for many duplicates, I'd go different.
1. With the info at hand, I have 2 ways that don't require a router but a table saw. you can rip 1/4" lath, mark off a jig on some ply and glue the strips together.
2. Rip 1/2" lath, mark up some ply for a jig lay the strips on the jig, mark the intersections and dado them out at 1/4". Jig and glue them then place them into the project
Ghidrah is offline
Small raised panel for a box S Bolton Table-mounted Routing 19 02-12-2008 04:32 PM
Raised Panel Bit rmaxa Router Bits - Types and Usage 3 09-13-2006 09:56 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
rasied panel doors jce Table-mounted Routing 6 12-13-2004 12:45 PM
