DeWalt 733 planer died today - Router Forums
 15Likes
post #1 of 38 (permalink) Old 09-18-2017, 04:43 PM Thread Starter
difalkner's Avatar
First Name: David
Default DeWalt 733 planer died today
I bought it new in 1997 and used it off and on for the first 17 years but in the last 3 I have used it a lot, sometimes daily. It has always run fine but today I turned it on and it ran for 1/2 a second then quit. Here's what I know:
1) It is getting power, I even switched to different circuit altogether
2) I pulled the switch out to verify that it is good
3) The brushes, though original, are still 1/2" long and show no signs of chipping or abnormal wear
4) The wires on the brushes are intact and the springs have plenty of tension
5) The motor is easy to spins (took the side covers off to verify)
6) The 18 amp built-in breaker on the top of the motor is in the position it should be in
7) In shining a light onto the commutator I see no chips or bridged arcs between segments
I don't really want to spend the money on a new planer and would rather get this one running again. I can order new brushes just to rule that out but again, the current ones look fine to me.
Ideas?
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #2 of 38 (permalink) Old 09-18-2017, 06:10 PM
David; did you do a simple continuity check to the load side of the switch?
When something was working and then it's not...what changed?
DaninVan is offline
post #3 of 38 (permalink) Old 09-18-2017, 06:13 PM
JOAT's Avatar
First Name: Theo
With me it was a drill press. Replaced the switch and that was all it took to fix it. Still going strong.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is offline
post #4 of 38 (permalink) Old 09-18-2017, 06:15 PM Thread Starter
difalkner's Avatar
First Name: David
That's what I don't understand. It has never given a hint of trouble and ran fine yesterday. When I turned it on today and it ran for a 1/2 second I thought it must have tripped a breaker. But everything else plugged into that same circuit runs fine. So I plugged it into another one with the same result. Then I pulled the switch completely out, plugged it in again, and checked power on both sides of the switch and there's a full 120 volts on the motor side of the switch.
This is the position of the breaker switch, looks to me like that's where it's supposed to be. And it doesn't want to move at all other than a slight rocking back and forth but it's always been like that. And it has never tripped.
David
David
Romans 3:23
post #5 of 38 (permalink) Old 09-18-2017, 07:14 PM
Jumpering a wire across the breaker contacts will prove if that's the problem at least. Just do that and turn it on. Be prepared to turn it off quickly too. It doesn't sound like a burned armature and you say it shows no signs. Usually there is a drop in power and rpm just before it quits if that is the problem. About the only other thing I can think of is a broken wire.
post #6 of 38 (permalink) Old 09-18-2017, 07:40 PM
do that to the breaker too...
post #7 of 38 (permalink) Old 09-18-2017, 08:13 PM Thread Starter
difalkner's Avatar
First Name: David
I may have to do that with the breaker but that means just about a full dismantle and I don't have time to do that until Thursday or Friday.
Thanks, Guys!
David
David
Romans 3:23
post #8 of 38 (permalink) Old 09-18-2017, 11:38 PM
Joe Lyddon's Avatar
First Name: Joe
Attachment 300066
Attachment 300074
David
I would get to the switch, detach some wire(s) and check the switch continuity when in ON & OFF positions...
Do the same thing to the Breaker / Fuse IN THE Machine... The Breaker could go bad... and if the breaker went bad, there is probably a REASON for it... ergo, another problem somewhere... (??)
Those two items should shed some light on it...
You have to check each one on it's own, NOT connected to the machine.
Let us know what happens, OK?
Good luck...
Have Fun,
Joe
Alta Loma, CA
www.WoodworkStuff.net
Joe Lyddon is offline
post #9 of 38 (permalink) Old 09-18-2017, 11:56 PM
The wire between the switch and motor OK? Is the breaker broken (just happened to an old one in my house panel.) Anything jammed in the blades, or any binding in the drive that rotates the blade?
DesertRatTom is online now
post #10 of 38 (permalink) Old 09-19-2017, 07:16 AM Thread Starter
difalkner's Avatar
First Name: David
Then I pulled the switch completely out, plugged it (the power cord) in again, and checked power on both sides of the switch and there's a full 120 volts on the motor side of the switch.
David
Good luck...
Did that already - see above. I can pull it again and check continuity but if it's getting 120 volts on the switched side then I'm going to say the switch is good. To get to the little breaker I've shown in the photo requires a full breakdown and I won't have time for that until the end of the week.
Thanks!
David
Joe Lyddon likes this.
David
Romans 3:23
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
used planer reikimaster Tools and Woodworking 19 04-22-2012 02:12 AM
got a brand new DEWALT 735 planner today at HD for $379 tryingtokeepmyfingers Lobby 5 07-25-2009 08:31 PM
planer decision... reikimaster Tools and Woodworking 9 10-08-2007 11:27 AM
I need help! Dewalt Planer Question FordPrefect Tools and Woodworking 4 12-12-2004 12:19 PM
