Band saw blade fluttering. - Page 2 - Router Forums
 5Likes
post #11 of 17 (permalink) Old 09-28-2017, 02:55 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Originally Posted by coxhaus View Post
I have not owned a Grizzly bandsaw so I can't help with the adjustment of the nuts. They look like something to do with the tension adjustment system. Maybe they tie to the upper wheel to make sure the wheel stays coplanar as it moves up and down.
With the forward and backwards movement can you see the blade moving forward and backwards on the wheels as it is spinning?
I would think there is no way to adjust the guides with the blade moving forward and backward.
PS
If the blade is moving on the wheel sounds like there is some slop on the upper wheel which means you need to call Grizzly on how to setup your tension system after it comes loose.
Lee I have called Grizzly and got just about no help I am going to order a new blade and see what happens. I that doesn't fix I will have to call Grizzly back and put more pressure on them to help me more.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #12 of 17 (permalink) Old 09-28-2017, 03:16 PM
First Name: lee
With the blade moving back and forth you can not adjust the guides. If the blade moves back while running it will cause the teeth to be hit by guides which dull the blade. I would fix the problem before I run a new blade on it.
coxhaus is offline
post #13 of 17 (permalink) Old 09-28-2017, 09:27 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Lee I called Grizzly back today and got a different person and he wants me to put more tension on the blade. So in the mourning I am going to put the 1/2" blade and run the tension up even higher. I thought I had to much tension on the blade but I will do what he told me. I hope I don't break any thing.
post #14 of 17 (permalink) Old 09-29-2017, 03:03 PM
First Name: lee
Did Grizzly happen to mention what the 2 nuts locked on the set screws? What do the 2 set screws adjust?
coxhaus is offline
post #15 of 17 (permalink) Old 09-30-2017, 06:47 AM Thread Starter
hawkeye10's Avatar
First Name: Don
I saw a video and the set screws are for adjusting the horizontal coplanar of the upper wheel.
TenGees likes this.
post #16 of 17 (permalink) Old 03-26-2018, 10:44 PM
Hawkeye10,
Did buying the new blade ever fix your issue? I'm going through something very similar to what you described.
Stowerscw is offline
post #17 of 17 (permalink) Old 03-28-2018, 07:13 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Yes did it help some but it still needs improvement. Here is a video showing how to make a jig to check tension. It's not going to cost me anything so I thought I would try it.
PS - I really think the best way to fix it is to buy a 14" Laguna Bandsaw. I had one and should have bought another one.
An Interesting Visit With A Lenox Band Saw blade Rep Jerry Bowen Tools and Woodworking 11 03-06-2019 06:32 PM
In Regard To The Broken Lenox BS Blade Jerry Bowen Tools and Woodworking 11 11-23-2015 01:20 AM
Any Thoughts On BS Blade Welds? Jerry Bowen Tools and Woodworking 16 10-27-2015 05:08 PM
Lenox Tri Master Blade For Sale: Jerry Bowen Lobby 0 02-17-2015 01:41 PM
Bosch 4100 EQUINOX400 Tools and Woodworking 23 09-16-2014 01:39 PM
