Thickness Planer Wood Defect....... - Router Forums
post #1 of 4 (permalink) Old 05-14-2005, 01:03 PM Thread Starter
Default Thickness Planer Wood Defect.......
HEY GUYS I HAVE A DELTA 13" THICKNESS PLANER AND I JUST RAN A PIECE OF OAK THROUGH IT AND ON THE SURFACE OF THE WOOD (ABOUT 2-1/2" INTO THE SHAVE) IS PUTTING A "STEP" IN THE SURFACE. IT ALSO IS PUTTING THIS STEP ABOUT 1-1/2" AT THE OPPOSITE END AS WELL. SO GOING IN AND COMING OUT IT LEAVES THIS NOTCH........... WHAT CAUSES THIS? MY INFEED AND OUTFEED TABLE SEEM TO BE LEVEL WITH EACH OTHER. NOW THE STEP IS VERY MINOR BUT NOTICEABLE. WHAT CAUSES THIS AND HOW CAN IT BE FIXED?
reds_21 is offline
post #2 of 4 (permalink) Old 05-14-2005, 05:46 PM
boxer's Avatar
First Name: kevin
Hey Reds, this happens when the wood passes one roller and is cut by the cutter. Once the wood reaches the second roller, it evens out. The same thing happens on the outfeed end. Some say to feed the board in at an angle, but this has never helped me. I just give the board a little lift as it goes into the roller, and as it comes out of the second roller. It takes a little practice and still leaves a little "step", but a light hit with the sander and you're good to go. I'm sure some of the veterans will have some ideas, but I don't know of any way to totally eliminate this problem.
Good luck,
Kevin
boxer is offline
post #3 of 4 (permalink) Old 05-14-2005, 10:55 PM
fibertech's Avatar
First Name: Derek
Send a message via AIM to fibertech
This is called "Sniping". It is common in most portable planers. It may even occur with larger planers. Cut your stock about 3 inches long on both end first. Also, you can put some waste stock in first and after your stock that is being used.
fibertech is offline
post #4 of 4 (permalink) Old 05-15-2005, 08:47 AM Thread Starter
thanks guys, i'll try that. so all in all it's not somehting that i was doing wrong!!! thats a good thing!!!
reds_21 is offline
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Router Planer Sled? Thinnest youíve cut wood? Nickbee Jigs and Fixtures 1 11-19-2007 11:51 AM
Thickness Planer Sled pmspirito Jigs and Fixtures 7 11-08-2007 01:44 PM
thickness planer mounting reds_21 Tools and Woodworking 4 08-07-2005 10:14 PM
Questions about wood Pallets and moisture GoonMan Tools and Woodworking 2 07-05-2005 08:11 PM
