Counter sink - Router Forums
post #1 of 2 (permalink) Old 02-05-2009, 01:35 PM Thread Starter
First Name: Steve
Default Counter sink
I need to drill some no. 8 screws 2 inches long into 3/4 plywood. I know I have asked things similar to this before, but what size do I need (drill bit).
Also, you can get drill bits with the countersink already on them. This is what I would like to get. Any thoughts?
Steve Bolton
S Bolton is offline
post #2 of 2 (permalink) Old 02-05-2009, 01:58 PM
AxlMyk's Avatar
I got a set or 2 similar to these. They can be had with a straight bit, or tapered.
http://peachtree-woodworking-supply-...B000XXZME8.htm
The last set I got was the Peachtree tapered set in a plastic case. I had been checking them out at the woodworking shows, and they had the best quality and smoothest grind on the bits.
AxlMyk is offline
Counter sinking metal S Bolton Jigs and Fixtures 13 01-20-2009 06:42 PM
counter top sink hole cabinet guy New Member Introductions 2 05-01-2008 09:49 PM
Counter Sink Bit Usage garycurtis Router Bits - Types and Usage 1 01-07-2008 05:04 PM
Sink trays rh111 Starting Off 3 02-06-2007 11:42 PM
