Knobs & Toggles - Router Forums
post #1 of 12 (permalink) Old 02-08-2009, 02:38 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Knobs & Toggles
I have a question on the attached
kolias is offline
post #2 of 12 (permalink) Old 02-08-2009, 02:43 PM
xplorx4's Avatar
First Name: Jerry
Greetings Nicolas, and welcome. I have not had any experience with taking those apart, probable if it were me I would just "take them apart" figuring they had to go together some how.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 12 (permalink) Old 02-08-2009, 02:52 PM
HI kolias
No to both
But you can make a longer one for the toggle hold down,,,just pick up a carr.bolt and grind it flat on the head and super glue a rubber tip in place ,,,you can get both items from the hardware store..
The 1/4" turn fastener, they do make them longer but not to much longer than you have now..you can screw on a rod coupling nut and some threaded rod to make it longer...the rod coupling nut is about 1" long on that size...little bit of rod and some super glue and you have it done..
post #4 of 12 (permalink) Old 02-08-2009, 03:52 PM
First Name: Greg
you can also buy longer spindles for the toggle clamps with the rubber feet attached:
http://www.grainger.com/Grainger/cat...mp-accessories
or you can buy just the cap to slip over a hex head bolt used for the spindle or threaded caps to screw on all-thread (scroll down to spindle caps):
http://www.mcmaster.com/#toggle-clamp-spindles/=imr88
Greg
gregW is offline
post #5 of 12 (permalink) Old 02-08-2009, 04:12 PM
Gerard_sr's Avatar
First Name: Gerard (AKA: Gerry )
Talking My Solution is shown attached.
Sorry Nicolas,
I didn't get the second attachment, picture, in your last email to me about it.
But My Solution is shown attached.
This should work.
Cordially,
Gerry
PS: I started with a 1/4-20 4" long flat head screw. I cut off the head. I drilled a 1/4" hole in a piece of scrap iron, put the threaded part in the hole with a nut on each side. Clamped it to my drill press table and drilled a #36 hole down into it, about 3/8". I then ran a tap into it for 6-32. I found a rubber foot, from some long gone electronic device, put a 6-32 3/8" long Phillips screw with a washer through it. I put a Washer-Nut on the shaft and screwed it into the end of the shaft.
Advantages are that the super glue won't break loose, same method can be used with threaded rod to a limit. (longer rods will bend!), washer-nut distributes the compression over a wider area, rubber foot can be had at electronics stores very inexpensively, the same goes for the 1/4-20 4" long screws.
Gerard_sr is offline
post #6 of 12 (permalink) Old 02-08-2009, 08:27 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Great answers
Thank you
kolias is offline
post #7 of 12 (permalink) Old 02-22-2009, 06:21 AM
Thelt's Avatar
First Name: Frank
Default knobs
On my Delta Midi the locking bolt on the tail shaft live center, similar to the one pictured, has broken off (the plastic piece). Anyone know of a substitute I can get at my big box store?
When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
Thelt is offline
post #8 of 12 (permalink) Old 02-22-2009, 08:10 AM
Gerard_sr's Avatar
Talking Howdy Frank!
Howdy Frank!
Without knowing the thread size, it makes things difficult.
But here's a link that might help you:
Tool Parts Direct
Cordially,
Gerry
PS: you should have started a new thread to get more answers.
post #9 of 12 (permalink) Old 02-22-2009, 08:39 AM
drasbell's Avatar
If the above link isn't what your looking for try this one
http://www.grizzly.com/catalog/2009/Main/246
look to the lower right hand corner.
drasbell is offline
post #10 of 12 (permalink) Old 02-22-2009, 09:23 AM
Gerard_sr's Avatar
Rick's got a good idea there, that is if you know the thread size, those may be stronger than the original replacement parts which my link was to.
Cordially,
Gerry
How to make my knobs S Bolton General Routing 8 11-26-2008 09:25 PM
Bobj3 homemade knobs Tale Gunner Jigs and Fixtures 8 07-02-2008 12:36 PM
Knobs and a question S Bolton General Routing 1 02-15-2008 09:05 PM
knobs delirous26 Jigs and Fixtures 2 09-16-2007 08:26 PM
brass knurled knobs general2 New Member Introductions 1 08-04-2006 04:37 PM
