guide to making zero clearance inserts ZCI - Router Forums
post #1 of 13 (permalink) Old 02-08-2009, 07:25 PM Thread Starter
First Name: pascal
Default guide to making zero clearance inserts ZCI
Funny thing - 2 weeks ago I didn't own a router or a table saw, and now I'm writing this
It didn't take long to learn that ever table saw should have a ZCI (Zero Clearance Insert). The benefits are reduced tearout on the bottom and small pieces don't fall into the rotating blade where they go round and round.
The table saw is a RIDGID TS2410LS though this should be good for most tables.
Step 1 - cut up some wood that is close to the size of the insert (1/16th to 1/8th border)
step 2 - wrap some tape in a loop and stick the original insert to the piece cut in step 1
step 3 - use a band saw, scroll saw, or anything of the sort to cut the rough shape of the insert out using the insert taped on in step 2 as a guide. This is important because you can't take more that 1/8th to 1/4" off with the router
step 4 - using a flush cut bit with the bearing set to the height of the original insert (on top) trim the blank insert to shape
step 5 - remove the original insert from the blank.
step 6 - using a zero clearance fence on the router table and a dado bit (groove cutter or whatever you would like to call it) cut the tab that holds the plate in place.
step 7 - test fit and make adjustments as needed. You might need to cut a dado for the blade if you can't lower the blade far enough. Measure and cut, every saw is going to be a little different.
step 8 - with the leveling screws on the original insert slightly extending, line up the original insert on top of the blank. gently tap with a rubber hammer - this will mark the location of the leveling screws.
step 9 - mark the "hold down" screw location with a permanent marker.
step 10 - remove the original insert and mark the dimples created in the step 6 with permanent marker so they are easier to see.
step 10 - drill the leveling screw holes with a bit that allows sufficient thread to bite into the blank insert
step 11 - using a bit that is larger than the head of the head of the screw you are using, drill in enough for the head of the screw to recess in - use your best judgment - I set the stop on the drill press so I could crank out a bunch once I got the height set.
step 12 - repeat step 11 for the hold down screw
step 13 - insert the screws with the heads sitting a touch above the surface, now grind the ends of the screws down while they are on the insert - this will size the screws and give them a flat surface for leveling.
step 14 - put in the table saw and level - you might need to grind the ends of the screws down a bit more - once I had a baseline the rest of the screws went very quickly
step 15 - with the insert leveled and the hold down screw in place, turn on the saw, allow the blade to get up to speed and gently raise though the insert to the height you want.
enjoy!
Name:	1 - IMG_1172_web.jpg
Name:	2 - IMG_1141_web.jpg
Name:	3 - IMG_1142_web.jpg
Name:	4 - IMG_1148_web.jpg
Name:	5 - IMG_1145_web.jpg
Name:	6 - IMG_1146_web.jpg
Name:	7 - IMG_1149_web.jpg
Name:	7B - IMG_1159_web.jpg
Name:	7C - IMG_1160_web.jpg
Name:	8 - IMG_1150_web.jpg
Name:	9 - IMG_1151_web.jpg
Name:	10 - IMG_1153_web.jpg
Name:	11 - IMG_1154_web.jpg
Name:	12 - IMG_1155_web.jpg
Name:	13 - IMG_1156_web.jpg
Name:	14 - IMG_1158_web.jpg
Name:	15 - IMG_1163_web.jpg
Name:	16 - IMG_1167_web.jpg
Name:	17 - IMG_1162_web.jpg
Name:	20 - IMG_1169_web.jpg
blurry is offline
post #2 of 13 (permalink) Old 02-08-2009, 07:45 PM
VERY NICE SHOW AND TELL pascal
Well done
post #3 of 13 (permalink) Old 02-09-2009, 12:23 AM
CanuckGal's Avatar
First Name: Deb
I want to do this with some acrylic. Should I use a different bit?
CanuckGal is offline
post #4 of 13 (permalink) Old 02-09-2009, 06:36 AM
harrysin's Avatar
First Name: Harry
A good thread and excellent photo shoot but could you reduce the size of the shots in future threads to something like 600 x 450 for faster opening.
Harry
harrysin is offline
post #5 of 13 (permalink) Old 02-09-2009, 07:12 AM
dovetail_65's Avatar
First Name: Dovetail
Harry don't they have a broadband connection out there yet? I did not want to say anything but your connection is as old as a dinosaur if those pics do not open instantly. Oops I forgot I am talking with an old dinosaur!
dovetail_65 is offline
post #6 of 13 (permalink) Old 02-09-2009, 08:21 AM Thread Starter
First Name: pascal
Those are reduced! Camera shoots way higher resolution than that! What kind of internet connection are you using?
blurry is offline
post #7 of 13 (permalink) Old 02-09-2009, 09:08 AM
HI Harry
They are see below, it's not compress that's why it takes a bit to load (file size is the key)
compress size would 22kb ....
Name:	image a .jpg
Name:	image ab 002.jpg
post #8 of 13 (permalink) Old 02-09-2009, 09:21 AM
Ghidrah's Avatar
First Name: Ronald
I made my 1st dado insert for the TS and bought a blank for the blade the phenolic is smooth. I use a stabilizer for my blades so I had to dig out the under side a bit so as to take advantage of an extra 1/2" of height.
Ghidrah is offline
post #9 of 13 (permalink) Old 02-09-2009, 09:40 AM
First Name: Joe
Send a message via MSN to petersenj20
Very nice write-up. Now I need an example for my Craftsman saw. They are much thinner and would have to be relieved on the underside. On my to do list. I currently have made one out of 1/4" mdf. Not the strongest material.
petersenj20 is offline
post #10 of 13 (permalink) Old 02-09-2009, 02:43 PM
Ghidrah's Avatar
First Name: Ronald
Be careful with the thickness, you don't want the insert to flex when you apply pressure to it as you pass material over it.
Ghidrah is offline
Zero clearance fence inserts Bogydave Table-mounted Routing 31 08-27-2011 02:06 PM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 09:08 AM
TS zero clearance inserts Router is still my name Tools and Woodworking 1 06-13-2008 12:39 AM
Safe clearance of bit to inside guide bush? MarkD Router Bits - Types and Usage 6 08-05-2006 07:57 AM
