Saw blade storage drawer - Router Forums
post #1 of 3 (permalink) Old 02-11-2009, 11:55 PM Thread Starter
Bogydave's Avatar
First Name: Dave
Default Saw blade storage drawer
Build a box large enough for the sawblades
Make some "T" hangers 5=1/4 tall for 10 inch blades )
Rout the odd number "T"s 5/8" deep with a 3/4" bit about 1/4" from the edge close to the clamped guide
Move the clamped down guide & rout the even number "T"s about 1/4" from the outside edge (same size)
(Mount a small block of wood to the back wall of the drawer with same grove to match up with the first "T" grove) space the "T"s 1/2" apart in order (screw & glue to center line in the bottom)
Cut some 1-1/2" long 1/2" thinwall PVC (may need to sand smaller if they don't fit in the 5/8" saw blade arbor hole)
Put the pvc thru the blade arbor hole & drop into the groves of the drawer
I made 3 front "T"s spaced 1-1/4" for Dado blades (that I don't have yet, just have wobble type)
storage part done, (add lipstick & make-up if you want, none so far in pic)
Life isn't right, wrong or fair. Life just is.
Bogydave is offline
post #2 of 3 (permalink) Old 02-12-2009, 02:17 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Nice way to hold your blades Dave.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 3 (permalink) Old 02-12-2009, 03:43 AM
xplorx4's Avatar
First Name: Jerry
I like that, now if I can think of a way to remember where it is when the basement is finished I could make one like it. Good idea, it is amazing that it does not take long to have more money in blades than in the saw itself.
Lamentations 3:22-23
xplorx4 is offline
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 4 04-10-2009 12:27 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
blade storage reible Tools and Woodworking 18 05-26-2006 07:50 PM
EZ Link DougO New Member Introductions 2 03-09-2006 12:52 PM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 10:20 AM
