Sleeveless sanding drums - Router Forums
post #1 of 14 (permalink) Old 02-12-2009, 01:44 AM Thread Starter
crquack's Avatar
Default Sleeveless sanding drums
Does anyone have experience with these:
http://www.ptreeusa.com/sandingdrums.htm
How do they compare with the standard sanding drums and sleeves?
crquack is offline
post #2 of 14 (permalink) Old 02-12-2009, 02:23 AM
derek willis's Avatar
First Name: Derek
I have had a set of these for more than ten yers, I find them excellent to use, and I don't have to buy drum sleeves, I can use a piece cut off from one of my rolls, although the smaller ones are a bit more awkward to fit.
derek.
derek willis is offline
post #3 of 14 (permalink) Old 02-12-2009, 06:03 AM
opelblues's Avatar
First Name: Gary
there a different brand here in oz, iv had a set for about 8 years... i find them great for when im working on my squatters chairs.
http://www.carbatec.com.au/sanding/s...nding-drum-set
opelblues is offline
post #4 of 14 (permalink) Old 02-12-2009, 10:06 AM
First Name: Maurice
Send a message via Skype™ to Maurice
I had a similar thing for my DeWalt radial arm saw.
the locking mechanism didn't hold very well.
Maurice is offline
post #5 of 14 (permalink) Old 02-12-2009, 10:13 AM
First Name: Derek
Maurice,
These lock very well indeed.
Derek.
post #6 of 14 (permalink) Old 02-12-2009, 10:26 AM
HI crquack
I had a set along time ago they are a bit lame, the sleeve type work so much better ... the disk (sleeves ) are cheap and so easy to switch out..one nut the norm of the shaft, no spec.tool to find or look for when you need to some more on.. plus you can get the drums from 40 to 440 grit.that will stand up for more than 30 sec.of sanding..because the cardboard drum is holding the paper in place..and adding support..
post #7 of 14 (permalink) Old 02-12-2009, 06:40 PM Thread Starter
crquack's Avatar
Interesting!
I am looking at them specifically because anything finer than 120 grit in the standard sleeve version seems rarer than hen's teeth.
crquack is offline
post #8 of 14 (permalink) Old 02-13-2009, 03:09 AM
First Name: Derek
Very true, I've fitted wet and dry very fine paper to mine for a specialist project.
Derek.
post #9 of 14 (permalink) Old 02-13-2009, 10:28 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
derek.
At one time, demonstrators used to work the UK shows promoting a patent one, although I've forgotten the brand name.
I needed something similar here in Croatia the other day and no-one knew what they were. I had a look on Axminster and Rutlands, both of whom were relatively expensive for Chinese versions, before settling for http://www.amazon.co.uk/exec/obidos/...A3P5ROKL5A1OLE
Incidentally, Amazon also listed those little corner chisels at UKP2.99 from the same source. http://www.amazon.co.uk/exec/obidos/...=ANC65A3J0328N
and a digital depth gauge that I thought could come in handy for fence adjustment for under a tenner
as well as four sided diamond sharpening blocks http://www.amazon.co.uk/exec/obidos/...A3P5ROKL5A1OLE for just over a tenner.
I hadn't realised before how useful Amazon UK could be. I'd initially gone looking for pipe thread dies for doing the pipes for pipe clamps and found http://www.amazon.co.uk/exec/obidos/...A3P5ROKL5A1OLE for UKP25 the set. They probably aren't robust enough for trade use, but for doing the occasional one should be fine. Individual dies are normally more than that.
Cheers
Peter
istracpsboss is offline
post #10 of 14 (permalink) Old 02-13-2009, 10:40 AM
AxlMyk's Avatar
Whatever type you get they work great for lawn mower blades. They don't burn the blade like a grinder does.
AxlMyk is offline
Sanding Tips pmspirito Tools and Woodworking 7 05-22-2009 08:49 AM
Sanding Sealer - What is it? Thrifty Tool Guy The Finishing Touch 11 02-21-2009 08:28 AM
Sanding paper everywhere... simplenik Tools and Woodworking 7 06-02-2007 12:57 AM
