Saw renovation question - Router Forums
 7Likes
post #1 of 16 (permalink) Old 11-11-2017, 05:19 PM Thread Starter
First Name: Lee
Default Saw renovation question
Hi, I have recently bought a Henry Disston saw as a renovation project, I have cleaned up the back and blade and straightened both. Unfortunately, the back edge of the saw has sheared off. The current handle position doesn't look right and when attached, the blade doesn't fit in the spine/back.
Can anyone advise me if the position is right? If not I was thinking of grinding the back section straight and re drilling holes for a new handle I have made.
Eazygeezer is offline
post #2 of 16 (permalink) Old 11-11-2017, 05:37 PM
best bet is that is not the original handle...
leave the blade and back alone and make a handle that fits...
keep the old handle...
Danman1957 likes this.
post #3 of 16 (permalink) Old 11-11-2017, 08:55 PM
The handle doesn't look quite right. Stick's right, make a new one. I think Paul Sellers has a video (and maybe a 10,000 word blog) on hand sharpening classic saws like this. Looking forward to seeing progress on the project.
Making a replacement handle for an antique saw.
Saw sharpening
post #4 of 16 (permalink) Old 11-11-2017, 09:09 PM
Lie Nielsen makes a tenon saw based on a Henry Disston saw from the early 20th century. Here's what it looks like: https://www.lie-nielsen.com/product/...non-saw-12-rip Seems to me I read recently that a tenon saw should be angled so that you get good downward force when cutting with them. I don't think that handle has quite enough angle to it.
DesertRatTom likes this.
post #5 of 16 (permalink) Old 11-12-2017, 09:46 AM
skiroy56's Avatar
First Name: Laurence
IMHO the saw back has shifted. Remove the tote, put the saw plate between two pieces of wood in the vise (preferably pine) and reset the back using a piece of wood to protect the spine with a hammer until parallel. Then I believe you will find that the tote is correct.
TwoSkies57 and DesertRatTom like this.
skiroy56 is offline
post #6 of 16 (permalink) Old 11-12-2017, 10:06 AM
TwoSkies57's Avatar
@skiroy56
The top front leading edge of the handle does appear to line up with the spine,but looking closely at the bottle edge of the spine towards the back near the handle there does appear to either have or have had moved at one time. Nice carch.
I do believe the handle to be common to the saw. Although in need of a bit of work.if I am not mistaken the slope of the saw plate compensates for the handle positioning.
@Eazygeezer
What are your plans for setting the teeth?
Skipper the Penguin
TwoSkies57 is offline
post #7 of 16 (permalink) Old 11-12-2017, 04:52 PM Thread Starter
First Name: Lee
Default Update
For some reason I could only upload 1 pic, the other 2 are in my album.
When the saw back is fully on the blade the top hole for the handle simply doesn't fit. It's a pretty crummy hack job, when the handle is on there's a steep angle from front to back and only about 2-3mm of the blade is slotted into the back. I have already made a new handle and it's ready to drill. I just wanted to be sure about the position before I drill the handle and look at setting/sharpening.
Can anyone recommend a good UK brand saw sharpening file/files?
I'm going to use the Paul sellers method, it's 10tpi so not quite sure of the set yet all advice gratefully taken
post #8 of 16 (permalink) Old 11-12-2017, 05:15 PM
Pounamu's Avatar
Country: New Zealand
First Name: Keith
Send a message via AIM to Pounamu Send a message via Skype™ to Pounamu
Maybe but if not it's a good copy. Or it may have been transplanted from another saw?
Here's mine (yes, I know, it could do with a good clean-up!).
If eating carrots improves the eyesight, how come there are so many dead rabbits on the roads?
Pounamu is offline
post #9 of 16 (permalink) Old 11-12-2017, 05:41 PM
leaning twoaeds a transplant...
Pounamu likes this.
post #10 of 16 (permalink) Old 11-19-2017, 05:14 PM Thread Starter
First Name: Lee
Here's a couple more pics. As you can see when the saw back is in place one of the handle holes is obscured. Is this normal? Should the back be inclined from front to handle?
Jewelry box question Barry747 Tools and Woodworking 14 12-31-2015 02:49 PM
Hello with a router fence question nevertoosafe New Member Introductions 9 11-02-2014 03:22 PM
Question About This Forum Jerry Bowen Tools and Woodworking 4 03-30-2012 10:46 AM
DC Question angus Lobby 3 03-31-2008 08:29 PM
