Toastmaster Tradesman - Router Forums
post #1 of 12 (permalink) Old 02-14-2009, 02:39 PM Thread Starter
Thelt's Avatar
First Name: Frank
Default Toastmaster Tradesman
Anybody ever see one of these? Found it in a junk sale, cost me $1.00. I bought it just for the novelty. It does run. I haven't tried to turn anything on it, yet. Maybe someday soon.
When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
Thelt is offline
post #2 of 12 (permalink) Old 02-14-2009, 03:54 PM
dutchman 46's Avatar
First Name: Howard
Well, That is the first time i seen one of those, Frank. Is that the same Co. that made small toaster ovens and smaller appliances? It just be the thing to turn some of the smaller spindles and the like. Good buy, My dollar just doesn't go that far.
John 3:16
dutchman 46 is offline
post #3 of 12 (permalink) Old 02-15-2009, 04:14 AM Thread Starter
Thelt's Avatar
First Name: Frank
I have since learned, from another forum, there are parts missing. For instance, on the motor end there is a small metal table that fits over the top and the small button you see on the top is where a jigsaw blade goes. I don't know who the manufacturer is, still researching.
Thelt is offline
post #4 of 12 (permalink) Old 02-15-2009, 11:54 AM
Ralph Barker's Avatar
First Name: Ralph
I would assume so, considering trademarks and such. Perhaps it dates to that period when many companies were "diversifying". You've probably seen the cartoons of military tank manufacturers also making baby buggies.
- Ralph
Ralph Barker is offline
post #5 of 12 (permalink) Old 02-16-2009, 04:48 AM Thread Starter
Thelt's Avatar
First Name: Frank
Here is the same model Toastmaster with the jigsaw table attached and the turning plate removed. I'm thinking of making a table out of wood that would be attached. What do you guys think. Probably just a waste of time, but I think it is a novelty.
Thelt is offline
post #6 of 12 (permalink) Old 02-21-2009, 07:06 PM
Hi Frank,
I just acquired one of these and it seems to have most of the attachments but missing the manual. Mine runs pretty noisy but seems to perform the functions OK. After I made the repair of the speed control dial, which was broken off, I found that the speed control doesn't change the speed all that much. Just wondering how yours works.
--Rich
Rich Bridygham is offline
post #7 of 12 (permalink) Old 02-22-2009, 04:58 AM Thread Starter
Thelt's Avatar
First Name: Frank
Originally Posted by Rich Bridygham View Post
Hi Frank,
--Rich
Yes it is quite noisy, and, the speed dial shows three speeds, (fast, medium & slow). Audibly I can hear two speed changes (don't seem to be a big difference). Still trying to figure out what all I'm missing beside the jig-saw table.
Frank
Thelt is offline
post #8 of 12 (permalink) Old 02-22-2009, 05:13 AM
I would think that with a bit of modification it could become a decent dedicated pen turning lathe. One thing is for sure Frank, you can't lose money on it.
Harry
Electron is offline
post #9 of 12 (permalink) Old 02-12-2013, 09:22 PM
First Name: jacob
Default noisy lathe
Frank
I realize this is an old thread, however i had this neat little lathe when i was but a youngling. inside the motor housing is a shaft and pin for the jigsaw to move up and down. this area is very likely in need of greese. if your getting alot of rattle or noise. you may also be missing a blade from the cooling fan on the motor itself. the spindle shaft is one solid piece. the motor windings sit inside several brass bushings. as far as the spped control, it's likely that if you only have two speeds one of the contacts are oxidized, a good contact cleaner (spray) will help. in the photo above there are several things i noticed missing one is the tool rest for the lathe chisel also i had a chuck for using drills which threaded onto the tail stock. it was nice to see they still exsist thanks for the post.
oldymoldy65 is offline
post #10 of 12 (permalink) Old 02-13-2013, 12:01 AM
Hi Jacob. Welcome to the forum.
Sydney, Australia
jw2170 is offline
