Mobile Bases - Router Forums
post #1 of 15 (permalink) Old 02-18-2009, 02:29 PM Thread Starter
First Name: Mark
Default Mobile Bases
Ok who's using what mobile bases and how well do the perform? I am looking at the jet umb. Does anyone have any experience with it? I am going to put most of my shop on mobile bases because I don't have enough room to work. The list consists of Table saw (Grizzly 1023sl), Jointer, band saw(Grizzly g0513x2) and drill press. As you can see the table saw is a big hefty so I am not sure about the movement of it. I appreciate all the input. Thanks.
AVman is offline
post #2 of 15 (permalink) Old 02-18-2009, 04:44 PM
Bob N's Avatar
First Name: Bob
Everything in my shop is mobile and it is the way to go for sure. I found myself building most of my mobile bases to get closer to what I needed and wanted instead of a packaged base. Your best casters can be had at Hartville Tools. Put "Woodnet discount" in the comments and get 15% off the regular price.
Bob N is offline
post #3 of 15 (permalink) Old 02-19-2009, 05:32 AM Thread Starter
First Name: Mark
Bob,
Does that discount work on most things they sell?
AVman is offline
post #4 of 15 (permalink) Old 02-19-2009, 06:10 AM
Bob N's Avatar
First Name: Bob
Everything that is not on sale. I think you also get 20% off on the Whiteside router bits.
Bob N is offline
post #5 of 15 (permalink) Old 02-19-2009, 11:42 AM
Ralph Barker's Avatar
First Name: Ralph
Fine Woodworking magazine did a comparison of mobile bases a while back. It might be helpful.
http://www.taunton.com/finewoodworki...F.aspx?id=2890
- Ralph
Ralph Barker is offline
post #6 of 15 (permalink) Old 02-19-2009, 01:08 PM
Hi AVman
Just one more way, it's so easy to make your own mobile bases,,,,,,
some 2" x 4" and some lap joints on the ends and you have them done,the casters are very cheap now days,see below...▼ plus you can make them to fit all your equipment just right , I made one last week because I broke off one caster on the side walk..if you want to see a snapshot just ask and I will post one...but it's very simple and easy job to make one..and it should save you big bucks the norm..
http://search.harborfreight.com/cpis...ters&Submit=Go
post #7 of 15 (permalink) Old 02-19-2009, 07:32 PM
scotirish10's Avatar
First Name: Ronald
This is the one on my table saw http://www.woodcraft.com/product.asp...&FamilyID=2026 and like it.
scotirish 10
Work safe: Remember the only 'SAFE' power tool in the shop, is the one with the plug pulled out of the socket!
If you have an open mind is there a chance your brain might fall out?
scotirish10 is offline
post #8 of 15 (permalink) Old 02-22-2009, 12:10 AM Thread Starter
First Name: Mark
Default 2 by Mobile Base
Are the casters below the equipment or to the sides? How does the effect the overall height? This sounds like a much cheaper solution.
Hi AVman
AVman is offline
post #9 of 15 (permalink) Old 02-22-2009, 10:06 AM
Hamlin's Avatar
First Name: Ken
Hi,
The majority of mine are mobile. The base under my TS came with it from Grizzly. Very sturdy. I recently made a MB for my router table. I intentionally used larger casters to help with the height. I hate stooping over and my back gets tired and sore from doing so.
I prefer mine to be directly underneath the tool(s). Less chance of "tripping" over them if needing to walk around them. I also prefer swivel locks.
Ken
"A VETERAN"
Hamlin is offline
post #10 of 15 (permalink) Old 02-22-2009, 10:22 AM
Hi AVman
I agree with Ken,, you don't want to make mobile base that will trip you up..
By using the lap joint will keep it a bit lower to the floor, if you mount the casters up and on the inside of the lap joint frame it will help keep the height down But it will make it hard to lock the casters up,,it's a toe thing..
I should note I have one like the that I use some 3/4" dowel pins that I push in with my toe to lock the wheels in place,, it just slides in and then I just slip it out when I need to move the tool around..many ways to skin the cat of this one..
Delta 50-345 Mobile Bases Thrifty Tool Guy Tools and Woodworking 14 02-15-2009 08:37 AM
putting together mobile bases and bandsaw levon Tools and Woodworking 23 01-25-2009 08:08 PM
Mobile bases AxlMyk Tools and Woodworking 0 03-30-2008 02:22 PM
