High Pressure Laminate - Router Forums
post #1 of 6 (permalink) Old 05-26-2005, 10:57 PM Thread Starter
reible's Avatar
Default High Pressure Laminate
Any one up on this subject?
Looking for places to buy it, any tricks to working with it, adhesives, experences?????
Ed
reible is offline
post #2 of 6 (permalink) Old 11-27-2005, 10:30 PM
Community Founder
Mark's Avatar
First Name: Mark
Reible, sorry for the delayed response, hopefully you're still searching for the High Pressure Laminate. Anyway, I was browsing google earlier this evening and I discovered a website.
http://wanlishiye.en.alibaba.com/pro...ate__HPL_.html
Let me know how it works out.
Mark,
Founder of RouterForums.com
Mark is offline
post #3 of 6 (permalink) Old 12-12-2005, 01:18 PM
The Router Guys
BobandRick's Avatar
Here is a start. Maybe check out NEMA this is where the product standards come from and they have information on the following:
1) Application, Fabrication, and Installation. 2) Care and Cleaning of Laminates. 3) Perception of Scratches. 4) Wear Resistance Chart.
The NEMA link
Rick and Bob
The Router Guys
Well I have just completed my first PDF E-Course, which is 10 embedded lessons from the Router Workshop Video Series. This is a must have PDF that you can get some very good pointers on how to use the router. Get your FREE copy here!
Click here to join the Router Workshop!!
BobandRick is offline
post #4 of 6 (permalink) Old 12-16-2005, 04:58 PM
Reible, I have used Wilsonart products in the past with good results. The solvent based contact cement is what I use. Google Wilsonart for a supplier hope this helps
Neanderthal is offline
post #5 of 6 (permalink) Old 12-31-2005, 10:35 PM
pmspirito's Avatar
First Name: Peter
I have had very good results using the water based contact cement. It goes on well with a paint roller and cleans up easily. Also there are no dangerous fumes.
pmspirito is offline
post #6 of 6 (permalink) Old 05-25-2015, 04:09 AM
Default high pressure decorative laminates
you can also select high pressure laminates at New Mika. This website contains wide range of textures.
newmika is offline
Plastic laminate S Bolton Table-mounted Routing 12 03-16-2008 07:40 PM
laminate counter top lyoncub Starting Off 2 01-10-2008 11:57 PM
Router and table for high school use. Lyle Wallin Table-mounted Routing 9 10-31-2005 04:49 AM
how high should my router table be? spydee Table-mounted Routing 6 07-03-2005 08:31 PM
