Drilling deep holes - Router Forums
post #1 of 31 (permalink) Old 02-24-2009, 12:02 PM Thread Starter
Default Drilling deep holes
In an effort to hide the connection, I thought it be cool (first mistake, being cheeky) to drill from the bottom of a 4 inch thick stock. I used a 12 inch 3/16th bit with a power drill and an adjustable drilling jig. (my drill press doenst have the "reach")the bit came out of the top about an 1/8 off the mark on one hole and about 1/16 for the other.
Can think of a couple of reasons it did this. First, the bit being that long and that thin flexed under pressure and "walked" as it cut thru. Then the drilling guide may not have been dirlectly over the hole, and the above mentioned off target hole may have simply spotted wrong from the get go.
I did start a deep pilot hole with a jig then switched to the long bit.
Is there a better, easier way to drill holes with out a drill press thru thick stock and have it come out where you want it too?
TIA
dan
dan_house is offline
post #2 of 31 (permalink) Old 02-24-2009, 02:16 PM
Bob N's Avatar
First Name: Bob
Dan,
If you came out that close over the course of 12", I really don't think you can ask for much more under the circumstances. Even a drill press would not have gotten you any closer. Just too many factors involved to do any better. About the only thing you could have done different would have been to drill from the top down and let the varance be hidden down below. I think you did pretty darn good myself.
Bob N is offline
post #3 of 31 (permalink) Old 02-24-2009, 02:20 PM
Ghidrah's Avatar
First Name: Ronald
I have a bunch of what I call drill blocks, I keep a set in the trailer and one in the shop. I use 3/4" plywood and set each bit in the drill press and make one plunge into the block starting at the outside of the block and work my way around the perimeter eventually ending in the center where the largest bit hole is. The 2nd block, gluing 2 blocks together, as the bit diameter grows so does the length of the bit the highest block is 3 lams at 2 1/4". I have blocks covering from 1/16" to a 1/2" in 32nd and 64th increments.
Quite often when perfect 90 holes are required in material too large for the press I use the blocks. Make the block long enough to clamp when necessary.
Ghidrah is offline
post #4 of 31 (permalink) Old 02-24-2009, 04:03 PM
Ralph Barker's Avatar
First Name: Ralph
Other factors that might come into play are the speed of the drill (rotation speed), the speed of the feed, and the type of bit being used. Slower speeds would likely result in less wander, allowing the bit to cut better, and a brad-point style bit might track more accurately.
- Ralph
Ralph Barker is offline
post #5 of 31 (permalink) Old 02-24-2009, 05:00 PM Thread Starter
Bob, the piece was only 4 inches deep/thick..... For me that was really good, but not good enough for the project.
thinking maybe to plug the the last inch of the hole (can hide the mend...), redrill down to the almost to the plug with a bigger bit, and redril the last inch with the smaller bit. Taht doesnt work, I'll plug the whole thing and redrill from the top..... not as elegant....but thats what prototypes are for, right?
Ralph, since I was drilling with my powerdrill, and hand feeding thru the jig, I bet your right about feed rates. I had to put s afiar amount of pressure to get it to drill,,,,,,
Ghidrah.. thats brilliant! I can see many applications for those.....
thanx guys
post #6 of 31 (permalink) Old 02-24-2009, 05:52 PM
HI Dan
It may be time to tune up your drill press
Put a square on the table top, and hold it to the side of the chuck it should be dead on, if not look under the top for a bolt/nut adjust the table so it's dead on with the chuck now move the square 90 deg. and do the same thing, if it's true your done it not find a business card and use it for a shim,you will need move the bolt or nut to get it in behind the mount, put one in, then check it one more time,if you are dead on move the top so it's square on the other side of the chuck.. it takes a bit of time to get it done but it's worth it in the long run..
TIA
dan
post #7 of 31 (permalink) Old 02-24-2009, 06:30 PM
Bob N's Avatar
First Name: Bob
thanx guys
Sorry about that! I mis-read and was thinking 12" deep
Bob N is offline
post #8 of 31 (permalink) Old 02-24-2009, 07:28 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I'm not sure what I'm missing here but what's wrong with drilling from both ends.
Harry
harrysin is offline
post #9 of 31 (permalink) Old 02-24-2009, 07:32 PM
HI Harry
I think that's something like burning the candle from both ends
It takes the fun out of it...
post #10 of 31 (permalink) Old 02-25-2009, 11:39 AM Thread Starter
Me? I'd never get them to line up...... so its all in one shot for me.
Maybe after another decade or two of experience.....
PVC Pipe Holes morbious Tools and Woodworking 3 02-15-2008 04:50 PM
Boring 5mm Holes for Shelf Pins garycurtis Router Bits - Types and Usage 4 12-20-2007 05:38 PM
Misaligned holes in phenolic plate jrs4464 New Member Introductions 1 08-08-2006 07:18 PM
Bench dog holes Bob N Tools and Woodworking 10 02-18-2005 11:23 AM
